Home » Newcomers » Newcomers » Trying to start Eclipse
Trying to start Eclipse [message #198098] Tue, 06 March 2007 13:17 Go to next message
Originally posted by: thefrozenthrone.gmail.com
I can't start Eclipse, I get the following on the log under configuration
!SESSION Tue Mar 06 13:06:34 EST 2007
!ENTRY org.eclipse.core.launcher 4 0 2007-03-06 13:06:34.343
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:639)
at org.eclipse.core.launcher.Main.basicRun(Main.java:274)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Trying to start Eclipse [message #198128 is a reply to message #198098] Tue, 06 March 2007 16:05 Go to previous message
> !STACK
This is usually because when you unzipped Eclipse you did not instruct
the ZIP tool to keep the directory structure intact. Make sure when you
unzip that you get all the proper subdirectories under the installation
location (plugins/, features/, etc.)
Hope this helps,
Eric
Previous Topic:Problem running ant ftp-task
Next Topic:want to configure Tomcat web server
Current Time: Wed Nov 05 17:14:19 EST 2025
Powered by FUDForum. Page generated in 0.07264 seconds
