Home » Archived » BIRT » Pagination Extension?
Pagination Extension? [message #198076] Fri, 27 October 2006 16:42 Go to next message
Originally posted by: trevor.l.torrez.accenture.com
Ok, I need a pagination type widget for html displays of large tables,
and JavaScript is not an option due to 508 considerations. What is the
best way to create this thing? Is it feasible to create an extension to
birt to provide a sort of high-level black box control I can place in
the report design? Do I need to extend birt itself to create and expose
this control? What are the best resources to look at for going about it
either way?
-t.
Re: Pagination Extension? [message #198525 is a reply to message #198076] Tue, 31 October 2006 15:16 Go to previous messageGo to next message
This sounds like a report item extension.
Take a look at this article.
http://java.sys-con.com/read/286915.htm
Jason
"Trevor Torrez" <trevor.l.torrez@accenture.com> wrote in message
news:ehtqtd$o0q$1@utils.eclipse.org...
> Ok, I need a pagination type widget for html displays of large tables, and
> JavaScript is not an option due to 508 considerations. What is the best
> way to create this thing? Is it feasible to create an extension to birt
> to provide a sort of high-level black box control I can place in the
> report design? Do I need to extend birt itself to create and expose this
> control? What are the best resources to look at for going about it either
> way?
> -t.
Re: Pagination Extension? [message #199011 is a reply to message #198525] Fri, 03 November 2006 13:12 Go to previous message
That looks like it should do the trick. Thanks.
> Jason
>> way?
>> -t.
-t.
Previous Topic:How to add a backgroundimage dynamically?
Next Topic:Run charts with BIRT viewer on Linux
Current Time: Fri Apr 25 18:02:56 EDT 2025
Powered by FUDForum. Page generated in 0.05380 seconds
