'Select *' query always generates error [message #198044] |
Fri, 27 October 2006 16:08 |
Originally posted by: goykhmanster.gmail.com
I am having a problem with BIRT report viewer.
Any time my query text has 'select *' in it (select all columns), i get
the following error on the report page:
Exception in:
ReportEngineService.runReport( )
Error happended while running the report
I am using BIRT report viewer 2.0.2 with Eclipse 3.1.
Has any of you ever got this problem? Is there a workaround? I would
appreciate any help. Thanks in advance.
Re: 'Select *' query always generates error [message #198348 is a reply to message #198211] |
Mon, 30 October 2006 15:48 |
This is the error from dataset editor:
An unexpected internal exception occurred.Please see log for detail.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Designer UI
Plug-in ID:org.eclipse.birt.report.designer.ui
Version:2.0.2
Error Code:Error.GUIException.invokedByUnexpectedException
Error Message:IClob.getSubString()
Re: 'Select *' query always generates error [message #198642 is a reply to message #198594] |
Wed, 01 November 2006 18:24 |
Originally posted by: bgoykhman.hotmail.com
Error 2006-10-31 14:30:29.196 Error Message:IClob.getSubString()
Info 2006-10-31 14:30:29.196 Version:2.0.2
Info 2006-10-31 14:30:29.196 Plug-in ID:org.eclipse.birt.report.designer.ui
Info 2006-10-31 14:30:29.196 Plug-in Name:BIRT Designer UI
Info 2006-10-31 14:30:29.196 Plug-in Provider:Eclipse.org
FUDForum. Page generated in 0.04745 seconds
