Home » Language IDEs » Java Development Tools (JDT) » Tomcat eclipse plugin error
Tomcat eclipse plugin error [message #198021] Wed, 09 March 2005 02:11
Originally posted by: stoutoleman.yahoo.com
Hello -
I am trying to debug a webapp of mine using eclipse 3.0 and the sysdeo
plugin. Starting and stopping both work fine, but when i try to go to
the root page of the webapp i get the below error. I have eclipse
setup to use the jdk jvm. Per your instructions, I have attached the
generated config file here. Any help you could offer would be greatly
appreciated. Note, when I start the server manually, it works, but
then I cannot debug.
Scott
// LOG FILE
-------- Launch Tomcat JVM Start --------
-> Label : Tomcat 5.x
-> ClassToLaunch : org.apache.catalina.startup.Bootstrap
-> Classpath : | project\classes | |
project\webroot\WEB-INF\compile-lib\javax.servlet.jar | |
project\webroot\WEB-INF\deploy-lib\commons-beanutils.jar | |
project\webroot\WEB-INF\deploy-lib\struts.jar | |
project\webroot\WEB-INF\deploy-lib\jai_core.jar | |
project\webroot\WEB-INF\deploy-lib\jai_codec.jar | | C:\Program
Files\eclipse\plugins\org.junit_3.8.1\junit.jar | |
project\webroot\WEB-INF\deploy-lib\mail.jar | | C:\Program
Files\Apache Software Foundation\Tomcat 5.0\bin\bootstrap.jar | |
C:\Program Files\Java\jdk1.5.0_01\lib\tools.jar |
-> BootClasspath :
-> Vmargs : -Dcatalina.home="C:\Program Files\Apache Software
Foundation\Tomcat 5.0" -Djava.endorsed.dirs="C:\Program Files\Apache
Software Foundation\Tomcat 5.0\common\endorsed"
-Dcatalina.base="C:\Program Files\Apache Software Foundation\Tomcat
5.0" -Djava.io.tmpdir="C:\Program Files\Apache Software
Foundation\Tomcat 5.0\temp"
-> PrgArgs : -config "C:\Program Files\Apache Software
Foundation\Tomcat 5.0\conf\server.xml" start
-> Debug : true
-------- Launch Tomcat JVM End--------
// BEGIN ERROR
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented
it from fulfilling this request.
exception
javax.servlet.ServletException:
javax.servlet.jsp.PageContext.getVariableResolver()Ljavax/se rvlet/jsp/el/VariableResolver;
org.apache.jasper.runtime.PageContextImpl.doHandlePageExcept ion(PageContextImpl.java:825)
org.apache.jasper.runtime.PageContextImpl.handlePageExceptio n(PageContextImpl.java:758)
org.apache.jsp.index_jsp._jspService(index_jsp.java:565)
org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:94)
javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:324)
org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:292)
org.apache.jasper.servlet.JspServlet.service(JspServlet.java :236)
root cause
java.lang.NoSuchMethodError:
org.apache.jasper.runtime.PageContextImpl.proprietaryEvaluat e(PageContextImpl.java:899)
org.apache.jsp.index_jsp._jspService(index_jsp.java:135)
note The full stack trace of the root cause is available in the Apache
Tomcat/5.0.28 logs.
Apache Tomcat/5.0.28
Previous Topic:Searching Files
Next Topic:Howto terminate external editor launched with IEditorLauncher
Current Time: Mon Oct 27 23:43:19 EDT 2025
Powered by FUDForum. Page generated in 0.07207 seconds
