Home » Eclipse Projects » Riena » IObjectTransaction.addReference()
IObjectTransaction.addReference() [message #1589] |
Mon, 19 May 2008 20:04 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ekkehard.gentz-software.de
the JavaDoc says:
Adds the reference to a child object simular to setReferenceObject with
the difference that the referenceName refers to an unsorted collection of
objects.
does this really mean, that you only support unsorted collections ?
no SortedSet, no List ?
thx for info
ekke
Re: IObjectTransaction.addReference() [message #2806 is a reply to message #2754] |
Tue, 20 May 2008 16:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
christian,
I think, at the moment I can live with these limitations -
if I found a situation where its really a stopper, I'll file a request.
So for now its the best I'll change some of my code-generation to use
also LinkedHashSet and ArrayList
ekke
Re: IObjectTransaction.addReference() [message #15679 is a reply to message #2806] |
Mon, 20 October 2008 10:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: fdo.scodi.ch
Hello
Has there anything changed about this state?
I'm trying to transfer EMF objects with Riena, which works great. The only
problem is the usage of EObjectResolvingEList, which is used as soon as I
have a multi reference field.
Example:
public List<RoleRef> getRoles() {
if (roles == null) {
roles = new EObjectResolvingEList<RoleRef>(RoleRef.class, this,
BasicPackage.PERSON_BASIC__ROLES);
return roles;
Is it planned to fix this issue?
Flavio
ekke wrote:
> christian,
> ekke
Re: IObjectTransaction.addReference() [message #15707 is a reply to message #15679] |
Mon, 20 October 2008 12:38 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Christian Campo![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=christian.campo%40compeople.de) Messages: 597 Registered: July 2009 |
Hi Flavio,
your posting does not really state what "the issue" is. Being an EMF nerd its also not clear why your posted statment
should not work with Riena.
And other than that, ekke said he can live with the limitation. If you cant, please file a bugreport. Thats the way
things get done. A thread on the newsgroups help people to understand problems and exchange information. They usually
never get things done.
And you need to explain in the bugreport what goes wrong. You can also try to fix it yourself and attach a patch but
thats not a requirement. I am just trying to encourage you :-)
christian
Flavio Donzé schrieb:
> Hello
> only problem is the usage of EObjectResolvingEList, which is used as
> soon as I have a multi reference field.
> Example: public List<RoleRef> getRoles() {
> return roles;
> Thanks
> Flavio
> ekke wrote:
>> christian,
>> ekke
Re: IObjectTransaction.addReference() [message #16464 is a reply to message #15707] |
Tue, 21 October 2008 12:34 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hey Christian
Sorry for not being so clear, I think I replied to the wrong post in the
first place.
I reported a bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=251501
Christian Campo wrote:
> Hi Flavio,
> christian
>> Hello
>> return roles;
>> Thanks
>> Flavio
>> ekke wrote:
>>> christian,
>>> ekke
Re: IObjectTransaction.addReference() [message #571084 is a reply to message #2754] |
christian,
ekke
Re: IObjectTransaction.addReference() [message #576560 is a reply to message #2806] |
Hello
Example:
return roles;
Flavio
ekke wrote:
> christian,
> ekke
Re: IObjectTransaction.addReference() [message #576569 is a reply to message #15679] |
Hi Flavio,
christian
> Hello
> return roles;
> Thanks
> Flavio
> ekke wrote:
>> christian,
>> ekke
Re: IObjectTransaction.addReference() [message #576666 is a reply to message #15707] |
hey Christian
first place.
> Hi Flavio,
> christian
>> Hello
>> return roles;
>> Thanks
>> Flavio
>> ekke wrote:
>>> christian,
>>> ekke
Current Time: Fri Jul 19 05:20:28 GMT 2024
Powered by FUDForum. Page generated in 0.04142 seconds
