Programmatically backup workspace [message #197926] |
Mon, 05 March 2007 21:50 |
Originally posted by: bensonc.ca.ibm.com
I am currently implementing a JUnit framework, one of the features
required is that if a test case fail or encounter errors, it will backup
the whole workspace programmatically and continue on with the next test
case. The backup workspace has to be able to relaunch again after the run
to perform futher investigation. Any suggestion of how to do this stably?
Thank you very much
NewComer
Benson
Re: Programmatically backup workspace [message #198181 is a reply to message #197926] |
Wed, 07 March 2007 08:05 |
Originally posted by: nugaee.SPAMtlen.pl
Benson wrote:
> run to perform futher investigation. Any suggestion of how to do this
> stably?
> Thank you very much
> NewComer
> Benson
bunch of hints :
you can use IWorkspace#copy method (to understand how it works please
read IResource#copy description)
you will also probably need
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/resAdv_concurrency.htm
hope this helps
bartek michalik
Re: Programmatically backup workspace [message #198264 is a reply to message #198181] |
Wed, 07 March 2007 15:52 |
I realize that IWorkspace#copy take IPath as the destination, does that
mean i cannot copy my workspce to my file system (outside of my
workspace)? Otherwise can you provide me more hits of how to do this?
Thank you very much
Benson
Re: Programmatically backup workspace [message #198340 is a reply to message #198264] |
Wed, 07 March 2007 20:24 |
Benson wrote:
> Thank you very much
> Benson
take a look on a Path class it can be build on any file system path
hope this helps
bartek michalik
Re: Programmatically backup workspace [message #198587 is a reply to message #198340] |
Thu, 08 March 2007 15:54 |
i have done some tracing through the debugger and found out that
IResource.copy calls Resource.copy which eventually calls
LocationValidator.validatePath(IPath, int, boolean)
in the comment of this method it say "Validates that the given workspace
path is valid for the given type."
This method will return an Invalid status even if i supply a Path
"C:\workspace".
does the IResource.copy really will allows me to copy file in my workspace
to my file system? it seems like the IPath for IResource.copy must take a
workspace path.
Thank you very much
Benson
FUDForum. Page generated in 0.10261 seconds
