| Home » Archived » BIRT » Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScript&qu
 Goto Forum:|
| Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScript&qu [message #197914] | Thu, 26 October 2006 18:51  |  |
| Eclipse User  |  |  |  |  | Originally posted by: home4slc.pacbell.net
 --------------050507090807010508070107
 Content-Type: text/plain; charset=us-ascii; format=flowed
 Im having trouble with on of the tutorials in the on-line help, "Field
 Guide to BIRT", and wondering if it is a bug or pilot error. I will be
 happy to enter a bugzilla if it is a bug if someone can take a moment to
 help with this.
 I completed tutorial 1 and have a sample report based on completing this
 tutorial.  In tutorial 5, Writing an event handler in JavaScript, I've
 found a problem when following the instructions.
 In Task 2 of Tutorial 5, Create and initialize a counter in
 Table.onCreate() method,
 the screen shot, Figure 22-5 shows the row called row["CUSTOMERNAME"],
 but I believe this should be dataSetRow["CUSTOMERNAME"].  (This is
 irrelevant to the problem later, but I believe the screen shot is
 incorrect?)
 Also, in Task 3, step 4 here is the JavaScript:
 CustName=row.getExpressionValue( "row[CUSTOMERNAME]" );
 The output I get when running the report only shows the first column's
 first row (cell 1) correctly (listing 1 below), and I'm getting a stack
 trace, and the CountOfMinis never increments. Here is the interesting
 part of the stack trace:
 (ThreadPool.java:683) at java.lang.Thread.run(Unknown Source)Caused by:
 org.mozilla.javascript.EcmaError: TypeError: Cannot call method
 "indexOf" of null (<inline>#3)
 So I changed the above line of JavaScript to this:
 CustName=row.getExpressionValue("row["CUSTOMERNAME"]");
 and I get all of the output, the CountOfMinis still does not increment
 and I get this stack trace (Listing 2);
 org.mozilla.javascript.EvaluatorException: missing ) after argument list
 (<inline>#4) at
 org.mozilla.javascript.DefaultErrorReporter.runtimeError(Def aultErrorReporter.java:95)
 I looked at the 2.1.1 version of the source and noticed that
 getExpressionValue has been decremented.  So I tried to modify the
 example to what I thought would be correct and I still have problems.
 I modified the code snippet for Task 3 to be this:
 CustName = this.getRowData().getColumnValue(0);
 Now I get the correct CountOfMinis, and no stack trace, but only the
 first cell appears.
 Can someone tell me the correct JavaScript to run this example?  I've
 also attached my report design file.
 Susan
 Listing 2
 The following items have errors:
 Data (id = 23):
 - There are errors evaluating script "row=this.getRowData();
 //CustName = this.getRowData().getColumnValue(0);
 //countOfMinis = row.getColumnValue("row[CUSTOMERNAME]");
 if( CustName.indexOf("Mini") != -1 )
 countOfMinis += 1;".
 Error.ScriptEvaluationError ( 122 time(s) )
 detail : org.eclipse.birt.report.engine.api.EngineException: There are
 errors evaluating script "row=this.getRowData();//CustName =
 this.getRowData().getColumnValue(0);//countOfMinis =
 row.getColumnValue("row[CUSTOMERNAME]");CustName=row.getExpressionValue( "row["CUSTOMERNAME"]");
 if( CustName.indexOf("Mini") != -1 ) countOfMinis += 1;". at
 org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:556)
 org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:528)
 org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleJSInternal(ScriptExecutor.java:66)
 org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.handleJS(ScriptExecutor.java:50)
 org.eclipse.birt.report.engine.script.internal.DataItemScrip tExecutor.handleOnCreate(DataItemScriptExecutor.java:52)
 org.eclipse.birt.report.engine.executor.DataItemExecutor.exe cute(DataItemExecutor.java:119)
 org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:35)
 org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutChildren(HTMLBlockStackingLM.java:63)
 org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:159)
 org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.resumeLayout(HTMLInlineStackingLM.java:94)
 org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.layoutChildren(HTMLInlineStackingLM.java:138)
 org.eclipse.birt.report.engine.layout.html.HTMLRowLM.layout( HTMLRowLM.java:30)
 org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutChildren(HTMLBlockStackingLM.java:68)
 org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.l ayoutChildren(HTMLTableBandLM.java:67)
 org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:74)
 org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout Children(HTMLPageLM.java:139)
 org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:81)
 org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:80)
 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:194)
 org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(Unknown
 Source) at
 Source) at
 org.eclipse.birt.report.service.BirtViewerReportService.runA ndRenderReport(Unknown
 Source) at
 org.eclipse.birt.report.service.actionhandler.BirtRunAndRend erActionHandler.__execute(Unknown
 Source) at
 org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
 Source) at
 org.eclipse.birt.report.presentation.aggregation.layout.Engi neFragment.doService(Unknown
 Source) at
 org.eclipse.birt.report.presentation.aggregation.AbstractBas eFragment.service(Unknown
 Source) at
 org.eclipse.birt.report.servlet.BirtEngineServlet.__doGet(Un known
 Source) at
 org.eclipse.birt.report.servlet.BaseReportEngineServlet.doGe t(Unknown
 Source) at  javax.servlet.http.HttpServlet.service(HttpServlet.java:740)
 org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
 at  javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at
 org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
 org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
 org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
 org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
 org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
 at  org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
 org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
 org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
 org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
 org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
 org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
 org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
 org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
 org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
 org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
 org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
 org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
 org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
 org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
 (<inline>#4) at
 org.mozilla.javascript.DefaultErrorReporter.error(DefaultErr orReporter.java:82)
 at org.mozilla.javascript.Parser.addError(Parser.java:120) at
 org.mozilla.javascript.Parser.reportError(Parser.java:126) at
 org.mozilla.javascript.Parser.mustMatchToken(Parser.java:212 ) at
 org.mozilla.javascript.Parser.argumentList(Parser.java:1595) at
 org.mozilla.javascript.Parser.memberExprTail(Parser.java:172 4) at
 org.mozilla.javascript.Parser.memberExpr(Parser.java:1640) at
 org.mozilla.javascript.Parser.unaryExpr(Parser.java:1500) at
 org.mozilla.javascript.Parser.mulExpr(Parser.java:1429) at
 org.mozilla.javascript.Parser.addExpr(Parser.java:1410) at
 org.mozilla.javascript.Parser.shiftExpr(Parser.java:1390) at
 org.mozilla.javascript.Parser.relExpr(Parser.java:1364) at
 org.mozilla.javascript.Parser.eqExpr(Parser.java:1320) at
 org.mozilla.javascript.Parser.bitAndExpr(Parser.java:1309) at
 org.mozilla.javascript.Parser.bitXorExpr(Parser.java:1298) at
 org.mozilla.javascript.Parser.bitOrExpr(Parser.java:1287) at
 org.mozilla.javascript.Parser.andExpr(Parser.java:1275) at
 org.mozilla.javascript.Parser.orExpr(Parser.java:1263) at
 org.mozilla.javascript.Parser.condExpr(Parser.java:1246) at
 org.mozilla.javascript.Parser.assignExpr(Parser.java:1228) at
 org.mozilla.javascript.Parser.assignExpr(Parser.java:1234) at
 org.mozilla.javascript.Parser.expr(Parser.java:1217) at
 org.mozilla.javascript.Parser.statementHelper(Parser.java:11 04) at
 org.mozilla.javascript.Parser.statement(Parser.java:616) at
 org.mozilla.javascript.Parser.parse(Parser.java:347) at
 org.mozilla.javascript.Parser.parse(Parser.java:287) at
 org.mozilla.javascript.Context.compileImpl(Context.java:2349 ) at
 org.mozilla.javascript.Context.compileString(Context.java:13 72) at
 org.mozilla.javascript.Context.compileString(Context.java:13 61) at
 org.eclipse.birt.core.script.ScriptContext.eval(ScriptContex t.java:221)
 org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:549)
 .... 65 more
 Listing 1
 Original example output
 Customer Phone Contact
 Alpha Cognac
 Oct 26, 2006 11:37 AM
 Data (id = 23):
 CustName=row.getExpressionValue("row[CUSTOMERNAME]");
 "row=this.getRowData();CustName=row.getExpressionValue("row[CUSTOMERNAME] ");
 Source) at
 Source) at
 Source) at
 Source) at
 Source) at
 Source) at
 Source) at
 Source) at
 "indexOf" of null (<inline>#3) at
 org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3240)
 org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3230)
 org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime .java:3246)
 org.mozilla.javascript.ScriptRuntime.typeError2(ScriptRuntim e.java:3265)
 org.mozilla.javascript.ScriptRuntime.undefCallError(ScriptRu ntime.java:3284)
 org.mozilla.javascript.ScriptRuntime.getPropFunctionAndThis( ScriptRuntime.java:1965)
 at org.mozilla.javascript.gen.c11._c0(<inline>:3) at
 org.mozilla.javascript.gen.c11.call(<inline>) at
 org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304)
 org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
 at org.mozilla.javascript.gen.c11.call(<inline>) at
 org.mozilla.javascript.gen.c11.exec(<inline>) at
 org.eclipse.birt.core.script.ScriptContext.eval(ScriptContex t.java:224)
 .... 65 more
 Content-Type: text/xml;
 name="customers.rptdesign"
 Content-Disposition: inline;
 filename="customers.rptdesign"
 <!-- Written by Eclipse BIRT 2.0 -->
 <report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.6" id="1">
 <property name="createdBy">Eclipse BIRT Designer Version 2.1.1.v20060922-1058 Build <20060926-0959></property>
 <property name="units">in</property>
 <property name="comments">Copyright (c) 2006 <<Your Company Name here>></property>
 <method name="afterFactory"><![CDATA[importPackage( Packages.javax.swing );
 frame = new JFrame( "Count of Minis = " + countOfMinis );
 frame.setBounds( 310, 220, 300, 20 );
 frame.show( );]]></method>
 <data-sources>
 <oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="4">
 <property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
 <property name="odaURL">jdbc:classicmodels:sampledb</property>
 <property name="odaUser">ClassicModels</property>
 </oda-data-source>
 </data-sources>
 <data-sets>
 <oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="customers" id="5">
 <structure name="cachedMetaData">
 <list-property name="resultSet">
 <structure>
 <property name="position">1</property>
 <property name="name">CUSTOMERNAME</property>
 <property name="dataType">string</property>
 </structure>
 <structure>
 <property name="position">2</property>
 <property name="name">CONTACTLASTNAME</property>
 </structure>
 <structure>
 <property name="position">3</property>
 <property name="name">CONTACTFIRSTNAME</property>
 </structure>
 <structure>
 <property name="position">4</property>
 <property name="name">PHONE</property>
 </structure>
 </list-property>
 </structure>
 <property name="dataSource">Data Source</property>
 <structure>
 <property name="nativeName">CUSTOMERNAME</property>
 <property name="nativeDataType">12</property>
 </structure>
 <structure>
 <property name="nativeName">CONTACTLASTNAME</property>
 </structure>
 <structure>
 <property name="nativeName">CONTACTFIRSTNAME</property>
 </structure>
 <structure>
 <property name="nativeName">PHONE</property>
 </structure>
 </list-property>
 <property name="queryText">select customerName,
 contactLastName,
 contactFirstName,
 phone
 from Customers </property>
 <xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
 <model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
 <Version>1.0</Version>
 <design:ResultSets derivedMetaData="true">
 <design:resultSetDefinitions>
 <design:resultSetColumns>
 <design:resultColumnDefinitions>
 <design:attributes>
 <design:name>CUSTOMERNAME</design:name>
 <design:position>1</design:position>
 <design:nativeDataTypeCode>12</design:nativeDataTypeCode>
 <design:precision>50</design:precision>
 <design:scale>0</design:scale>
 <design:nullability>Nullable</design:nullability>
 </design:attributes>
 <design:usageHints>
 <design:label>CUSTOMERNAME</design:label>
 <design:formattingHints>
 <design:displaySize>50</design:displaySize>
 </design:formattingHints>
 </design:usageHints>
 </design:resultColumnDefinitions>
 <design:attributes>
 <design:name>CONTACTLASTNAME</design:name>
 <design:position>2</design:position>
 <design:usageHints>
 <design:label>CONTACTLASTNAME</design:label>
 <design:attributes>
 <design:name>CONTACTFIRSTNAME</design:name>
 <design:position>3</design:position>
 <design:usageHints>
 <design:label>CONTACTFIRSTNAME</design:label>
 <design:attributes>
 <design:name>PHONE</design:name>
 <design:position>4</design:position>
 <design:usageHints>
 <design:label>PHONE</design:label>
 </design:resultSetColumns>
 </design:resultSetDefinitions>
 <design:attributes>
 <design:attributes>
 <design:attributes>
 <design:attributes>
 </design:ResultSets>
 </model:DesignValues>]]></xml-property>
 </oda-data-set>
 </data-sets>
 <page-setup>
 <simple-master-page name="Simple MasterPage" id="2">
 <page-footer>
 <text id="3">
 <property name="contentType">html</property>
 <text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
 </text>
 </page-footer>
 </simple-master-page>
 </page-setup>
 <body>
 <text id="29">
 <text-property name="content"><![CDATA[<CENTER><B><span style="font-size: larger">
 Customer List
 </B></span><BR>
 <FONT size="small">For internal use only</FONT><BR><BR>
 Report generated on <VALUE-OF>new Date( )</VALUE-OF>
 </CENTER><BR><BR>
 ]]></text-property>
 </text>
 <table id="6">
 <property name="width">100%</property>
 <property name="dataSet">customers</property>
 <list-property name="boundDataColumns">
 <structure>
 <expression name="expression">dataSetRow["CUSTOMERNAME"]</expression >
 </structure>
 <structure>
 <expression name="expression">dataSetRow["PHONE"]</expression>
 </structure>
 <structure>
 <expression name="expression">dataSetRow["CONTACTFIRSTNAME"]+" "+row["CONTACTLASTNAME"]</expression>
 </structure>
 <structure>
 <expression name="expression">dataSetRow["CONTACTLASTNAME"]</expression >
 </structure>
 </list-property>
 <method name="onCreate"><![CDATA[countOfMinis = 0;]]></method>
 <list-property name="sort">
 <structure>
 <expression name="key">row["CUSTOMERNAME"].toUpperCase()</expression >
 <property name="direction">asc</property>
 </structure>
 </list-property>
 <column id="19"/>
 <column id="20"/>
 <column id="21"/>
 <header>
 <row id="7">
 <cell id="8">
 <label id="22">
 <text-property name="text">Customer</text-property>
 </label>
 </cell>
 <cell id="9">
 <label id="24">
 <text-property name="text">Phone</text-property>
 </label>
 </cell>
 <cell id="10">
 <label id="26">
 <text-property name="text">Contact</text-property>
 </label>
 </cell>
 </row>
 </header>
 <detail>
 <row id="11">
 <cell id="12">
 <data id="23">
 <property name="paddingTop">12pt</property>
 <method name="onCreate"><![CDATA[row=this.getRowData();
 //CustName = row.getColumnValue("row[CUSTOMERNAME]");
 //CustName=row.getExpressionValue("row["CUSTOMERNAME"]");
 countOfMinis += 1;]]></method>
 <property name="resultSetColumn">CUSTOMERNAME</property>
 </data>
 </cell>
 <cell id="13">
 <data id="25">
 <property name="resultSetColumn">PHONE</property>
 </data>
 </cell>
 <cell id="14">
 <data id="27">
 <property name="resultSetColumn">CONTACTFIRSTNAME</property>
 </data>
 </cell>
 </row>
 </detail>
 <footer>
 <row id="15">
 <cell id="16"/>
 <cell id="17"/>
 <cell id="18"/>
 </row>
 </footer>
 </table>
 </body>
 </report>
 --------------050507090807010508070107--
| Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #198097 is a reply to message #197914] | Fri, 27 October 2006 18:50   |  |
| Eclipse User  |  |  |  |  | Thanks for your detailed comments. The online help, including the tutorials, is based on release 2.1.0 of BIRT. There have been some changes between
 2.1.0 and 2.1.1, which may be causing some of the problems that you're
 experiencing. I'll look at these issues and let you know the outcome as soon
 as I can. I'm not personally familiar with Tutorial 5, but I'll pass your
 comments onto my colleague who wrote the tutorial. Unfortunately, he is
 taking some vacation right now, but he'll be back in the office next
 Thursday.
 Jane Tatchell
 BIRT documentation lead
 "Susan Cline" <home4slc@pacbell.net> wrote in message
 news:ehre4j$fjv$1@utils.eclipse.org...
 > help with this.
 > incorrect?)
 > (<inline>#4) at
 > at
 > first cell appears.
 > Susan
 > Listing 2
 > Data (id = 23):
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > Source) at
 > Source) at
 > Source) at
 > Source) at
 > Source) at
 > Source) at
 > Source) at
 > Source) at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > (<inline>#4) at
 > at
 > at
 > ... 65 more
 > Listing 1
 > Alpha Cognac
 > Data (id = 23):
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > Source) at
 > Source) at
 > Source) at
 > Source) at
 > Source) at
 > Source) at
 > Source) at
 > Source) at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > at
 > ... 65 more
 > id="1">
 > here>></property>
 >    <data-sources>
 >        <oda-data-source
 > id="4">
 >            <property
 >        </oda-data-source>
 >    </data-sources>
 >    <data-sets>
 >        <oda-data-set
 >                    <structure>
 >                    </structure>
 >                    <structure>
 >                    </structure>
 >                    <structure>
 >                    </structure>
 >                    <structure>
 >                    </structure>
 >                </list-property>
 >            </structure>
 >                <structure>
 >                </structure>
 >                <structure>
 >                </structure>
 >                <structure>
 >                </structure>
 >                <structure>
 >                </structure>
 >            </list-property>
 > contactLastName,
 > contactFirstName,
 > phone
 > <model:DesignValues
 >          <design:attributes>
 >          <design:usageHints>
 >          <design:attributes>
 >          <design:usageHints>
 >          <design:attributes>
 >          <design:usageHints>
 >          <design:attributes>
 >          <design:usageHints>
 >          <design:attributes>
 >          <design:attributes>
 >          <design:attributes>
 >          <design:attributes>
 >        </oda-data-set>
 >    </data-sets>
 >    <page-setup>
 >            <page-footer>
 >                <text id="3">
 >                </text>
 >            </page-footer>
 >    </page-setup>
 >    <body>
 >        <text id="29">
 > Customer List
 > </B></span><BR>
 > </CENTER><BR><BR>
 > ]]></text-property>
 >        </text>
 >        <table id="6">
 >                <structure>
 >                    <expression
 >                </structure>
 >                <structure>
 >                    <expression
 >                </structure>
 >                <structure>
 >                    <expression
 >                </structure>
 >                <structure>
 >                    <expression
 >                </structure>
 >            </list-property>
 >                <structure>
 >                    <expression
 >                </structure>
 >            </list-property>
 >            <column id="19"/>
 >            <column id="20"/>
 >            <column id="21"/>
 >            <header>
 >                <row id="7">
 >                    <cell id="8">
 >                        <label id="22">
 >                            <text-property
 >                        </label>
 >                    </cell>
 >                    <cell id="9">
 >                        <label id="24">
 >                            <text-property
 >                        </label>
 >                    </cell>
 >                    <cell id="10">
 >                        <label id="26">
 >                            <text-property
 >                        </label>
 >                    </cell>
 >                </row>
 >            </header>
 >            <detail>
 >                <row id="11">
 >                    <cell id="12">
 >                        <data id="23">
 >                            <method
 >                            <property
 >                        </data>
 >                    </cell>
 >                    <cell id="13">
 >                        <data id="25">
 >                            <property
 >                        </data>
 >                    </cell>
 >                    <cell id="14">
 >                        <data id="27">
 >                            <property
 >                        </data>
 >                    </cell>
 >                </row>
 >            </detail>
 >            <footer>
 >                <row id="15">
 >                    <cell id="16"/>
 >                    <cell id="17"/>
 >                    <cell id="18"/>
 >                </row>
 >            </footer>
 >        </table>
 >    </body>
 > </report>
| Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #198115 is a reply to message #198097] | Fri, 27 October 2006 19:55   |  |
 Thanks Jane.
 In the meantime I'll see if I can figure out the correct usage and post
 a corrected example.
 Susan
 > Thursday.
| Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #198379 is a reply to message #198097] | Mon, 30 October 2006 17:19   |  |
 I played with this example some more and I'm thinking there might be a
 bug with the way the word "row" is parsed.
 For Task 3 of Tutorial 5 here is the script that is supposed to be typed
 into the onCreate method of the Script tab for the detailed row
 CUSTOMERNAME.
 CustName = row.getExpressionValue("row[CUSTOMERNAME]");
 if (CustName.indexOf("Mini") != -1)
 countOfMinis +=1;
 As I mentioned in my previous email, running this script causes this
 partial listing of the stack trace:
 (This is the primary source: org.mozilla.javascript.EcmaError:
 TypeError: Cannot call method "indexOf" of null (<inline>#3) at
 ..... lots of stuff cut out.....
 at java.lang.Thread.run(Thread.java:534)Caused by:
 at org.mozilla.javascript.gen.c183._c0(<inline>:3) at
 org.mozilla.javascript.gen.c183.call(<inline>) at
 at org.mozilla.javascript.gen.c183.call(<inline>) at
 org.mozilla.javascript.gen.c183.exec(<inline>) at
 .... 65 more
 However, if you change the example to use this for the onCreate method:
 myrow=this.getRowData();
 CustName = myrow.getExpressionValue("row[CUSTOMERNAME]");
 countOfMinis +=1;
 The example executes correctly.  Also, I tried this for the script;
 CustName = this.getRowData().getExpressionValue("row[CUSTOMERNAME]");
 countOfMinis +=1;
 and it works fine as well.
 So it appears like there might be some kind of parsing problem on the
 word "row" in the first example.  It looks like the word "row" in the
 getExpressionValue method is being confused with the JavaScript
 variable, row.
 I'll enter a bugzilla bug for this.  Also, I would be happy to help
 correct this tutorial example.  Other than providing a correct example
 (until the bug is fixed, if it is a bug), is there another methodology
 for providing information to correct documentation examples?  For
 instance, should I log a bugzilla for documentation issues as well?
 I believe I found an error in another document on the web site that I
 would like to report and provide a corrected example for as well.
 Susan
 > Thursday.
| Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #199041 is a reply to message #198379] | Fri, 03 November 2006 15:03   |  |
| Eclipse User  |  |  |  |  | You are correct that there is a problem with the variable name, "row".  It appears that "row" is now a prohibited variable name.
 There is another problem with the tutorial, however. It is no longer
 possible to access a variable within one handler if that varialbe was
 created in different event handler. Well, there is a way, but the tutorial
 tries to use the old method. The variable "countOfMinis" must be a
 serializable Java object and the methods that save and retrieve the
 serializable object are reportContext.setPersistentGlobalVariable( ) and
 reportContext.getPersistentGlobalVariable( ). The correct code for the three
 event handlers is:
 Table.onCreate:
 countOfMinis = new Packages.java.lang.Integer("1");
 reportContext.setPersistentGlobalVariable("cmKey", countOfMinis);
 Row.onCreate:
 countOfMinis = reportContext.getPersistentGlobalVariable("cmKey");
 row_Data = this.getRowData();
 CustName = row_Data.getExpressionValue( "row[CUSTOMERNAME]" );
 if(CustName.indexOf("Mini") != -1){
 mCount = countOfMinis.intValue();
 mCount += 1;
 countOfMinis = new Packages.java.lang.Integer(mCount);
 ReportDesign.afterFactory:
 countOfMinis =
 reportContext.getPersistentGlobalVariable("cmKey").intValue();
 frame.show( );
 (Thanks to Jason Weathersby for helping me debug this.)
 news:ei5toa$l2m$1@utils.eclipse.org...
 > I played with this example some more and I'm thinking there might be a bug
 > CUSTOMERNAME.
 > countOfMinis +=1;
 > (This is the primary source: org.mozilla.javascript.EcmaError: TypeError:
 > at
 > at
 > at
 > at
 > org.mozilla.javascript.EcmaError: TypeError: Cannot call method "indexOf"
 > at
 > at  org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime .java:3246)
 > at
 > at
 > at
 > at  org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
 >  org.eclipse.birt.core.script.ScriptContext.eval(ScriptContex t.java:224) at
 > ... 65 more
 > countOfMinis +=1;
 > countOfMinis +=1;
 > So it appears like there might be some kind of parsing problem on the word
 > getExpressionValue method is being confused with the JavaScript variable,
 > row.
 > (until the bug is fixed, if it is a bug), is there another methodology for
 > providing information to correct documentation examples?  For instance,
 > Susan
 >> changes between 2.1.0 and 2.1.1, which may be causing some of the
 >> problems that you're experiencing. I'll look at these issues and let you
 >> know the outcome as soon as I can. I'm not personally familiar with
 >> Tutorial 5, but I'll pass your comments onto my colleague who wrote the
 >> tutorial. Unfortunately, he is taking some vacation right now, but he'll
 >> be back in the office next Thursday.
| Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #199126 is a reply to message #199041] | Fri, 03 November 2006 18:42   |  |
 Hi Don,
 Thanks for your help with this.  I logged a bug for the problem when
 using the word "row" in the JavaScript titled "Report Engine error
 parsing word "row" in evaluating JavaScript", bugzilla 162817.
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=162817
 This was changed to a doc bug so the tutorial example could be
 corrected.  However, I made a comment to this bug that I thought that
 BIRT should somehow throw a better error message when the word "row" is
 encountered in a script and used as a variable.
 So I'm not sure if I should log a new bugzilla for the tutorial
 correction or the existing bugzilla # should be used.  No one has
 commented on the bug yet, so I'm not sure what is going on with it.
 Susan
 > event handlers is:
 > Table.onCreate:
 > Row.onCreate:
 >     mCount += 1;
 > countOfMinis =
 > frame.show( );
 >>Hi,
 >>CUSTOMERNAME.
 >>countOfMinis +=1;
 >>at
 >>at
 >>at
 >>at
 >>at
 >>at
 >>at
 >>at
 >>... 65 more
 >>countOfMinis +=1;
 >>countOfMinis +=1;
 >>row.
 >>Regards,
 >>Susan
| Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #201257 is a reply to message #199126] | Thu, 16 November 2006 11:29   |  |
 Bug 162817 has been changed to a Report Designer bug.  Should I log a
 bugzilla for the tutorial?
 Susan
 Susan Cline wrote:
 > Hi Don,
 > Susan
 >> tutorial tries to use the old method. The variable "countOfMinis" must
 >> be a serializable Java object and the methods that save and retrieve
 >> the serializable object are reportContext.setPersistentGlobalVariable(
 >> ) and reportContext.getPersistentGlobalVariable( ). The correct code
 >> for the three event handlers is:
 >> Table.onCreate:
 >> Row.onCreate:
 >>     mCount += 1;
 >> countOfMinis =
 >> frame.show( );
 >>> Hi,
 >>> a bug with the way the word "row" is parsed.
 >>> typed into the onCreate method of the Script tab for the detailed row
 >>> CUSTOMERNAME.
 >>> countOfMinis +=1;
 >>> at
 >>> at
 >>> at
 >>> at
 >>> at
 >>> at
 >>> at
 >>> at
 >>> at
 >>> at
 >>> at
 >>> ... 65 more
 >>> countOfMinis +=1;
 >>> countOfMinis +=1;
 >>> variable, row.
 >>> example (until the bug is fixed, if it is a bug), is there another
 >>> methodology for providing information to correct documentation
 >>> examples?  For instance, should I log a bugzilla for documentation
 >>> issues as well?
 >>> Regards,
 >>> Susan
 >>>> you know the outcome as soon as I can. I'm not personally familiar
 >>>> with Tutorial 5, but I'll pass your comments onto my colleague who
 >>>> wrote the tutorial. Unfortunately, he is taking some vacation right
 >>>> now, but he'll be back in the office next Thursday.
| Re: Tutorial 5, Field Guide to BIRT, problem running the "Writing an event handler in JavaScrip [message #203177 is a reply to message #201257] | Mon, 27 November 2006 18:04  |  |
 I logged a bugzilla for the tutorial itself since the example has not
 been corrected as of 2.2.0 M1.
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=165982
 Susan
 > Susan
 > Susan Cline wrote:
 >> Hi Don,
 >> is encountered in a script and used as a variable.
 >> Thanks,
 >> Susan
 >>> must be a serializable Java object and the methods that save and
 >>> retrieve the serializable object are
 >>> Table.onCreate:
 >>> Row.onCreate:
 >>>     mCount += 1;
 >>> countOfMinis =
 >>> frame.show( );
 >>>> Hi,
 >>>> row CUSTOMERNAME.
 >>>> countOfMinis +=1;
 >>>> at
 >>>> at
 >>>> at
 >>>> at
 >>>> at
 >>>> at
 >>>> at
 >>>> at
 >>>> at
 >>>> at
 >>>> at
 >>>> ... 65 more
 >>>> countOfMinis +=1;
 >>>> countOfMinis +=1;
 >>>> the word "row" in the first example.  It looks like the word "row"
 >>>> in the getExpressionValue method is being confused with the
 >>>> JavaScript variable, row.
 >>>> issues as well?
 >>>> I would like to report and provide a corrected example for as well.
 >>>> Regards,
 >>>> Susan
 >>>>> let you know the outcome as soon as I can. I'm not personally
 >>>>> familiar with Tutorial 5, but I'll pass your comments onto my
 >>>>> colleague who wrote the tutorial. Unfortunately, he is taking some
 >>>>> vacation right now, but he'll be back in the office next Thursday.
 Current Time: Fri Oct 31 04:31:04 EDT 2025
 Powered by FUDForum . Page generated in 0.05265 seconds |
