Home » Eclipse Projects » GEF » ediagram example ok to use with eclipse 3.1.1?
ediagram example ok to use with eclipse 3.1.1? [message #197882] Thu, 06 October 2005 05:11 Go to next message
Jason Grant is currently offline Jason GrantFriend
Member
I'm getting the following compile errors with the ediagram example from
the cvs head:
The type DiagramLayoutEditPolicy must implement the inherited abstract
method ConstrainedLayoutEditPolicy.createAddCommand(EditPart, Object)
DiagramLayoutEditPolicy.java
The type EDiagramEditor must implement the inherited abstract method
GraphicalEditorWithFlyoutPalette.getPalettePreferences()
EDiagramEditor.java
There is no dependency version information in the manifest for this
project, so I'm not clear on what the couplings are. Is it ready for use
with eclipse 3.1.1, gef 3.1.1 and emf 3.1.1?
Jason.
Re: ediagram example ok to use with eclipse 3.1.1? [message #197928 is a reply to message #197882] Thu, 06 October 2005 13:30 Go to previous messageGo to next message
Member
OK, the following seems to indicate that cvs head contains a 3.2
enhancement, so I'll pull a tagged 3.1 version of the sample and see if
that works.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=109919
Re: ediagram example ok to use with eclipse 3.1.1? [message #197961 is a reply to message #197928] Thu, 06 October 2005 13:54 Go to previous message
Please note that the eDiagram example is on our 3.1.1 downloads page.
You probably meant this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=107069
"Jason Grant" <junk@logular.com> wrote in message
news:pan.2005.10.06.13.30.10.91497@logular.com...
> that works.
Previous Topic:Restrictions when creating connections
Next Topic:Selection Problem in MultiPageEditor using GEF
Current Time: Thu Nov 14 08:58:15 GMT 2024
Powered by FUDForum. Page generated in 0.24743 seconds
