| How can I force the workbench to switch to a perspective [message #18812] |
Tue, 02 September 2008 09:21  |
Originally posted by: yeronimuz.aol.com
I have an RCP with a boring perspective. So when my fancy plugin is activated, I want to switch to
the perspective of the plugin when the editor of this plugin is activated.
How should I do that?
Jeroen.
| Re: How can I force the workbench to switch to a perspective [message #18904 is a reply to message #18881] |
Wed, 03 September 2008 07:12  |
>> activated, I want to switch to the perspective of the plugin when the
>> Thanks,
>> Jeroen.
> After some workbench errors and other 'challenges', I found a solution:
> In my plugin.java I write in the constructor:
> getWorkbench().getPerspectiveRegistry().setDefaultPerspectiv e( "designer.perspective1");
> I'm not sure if this is the best place, but anyhow, it works.
> Jeroen.
I was cheering to soon. Now every time I start the RCP, it gives an error about not being able to
restore the "designer" perspective. That's probably because the designer is not known at that
specific moment.
Where should I put this switch perspective?
| Re: How can I force the workbench to switch to a perspective [message #578180 is a reply to message #18812] |
Wed, 03 September 2008 03:29  |
> Jeroen.
Jeroen.
| Re: How can I force the workbench to switch to a perspective [message #578242 is a reply to message #18881] |
>> Thanks,
>> Jeroen.
> Jeroen.
specific moment.
FUDForum. Page generated in 0.06967 seconds
