Home » Language IDEs » Java Development Tools (JDT) » M5: java.lang.NoClassDefFoundError when doing ANT stuff
M5: java.lang.NoClassDefFoundError when doing ANT stuff [message #196339] Mon, 21 February 2005 01:52 Go to next message
Windows XPSP1
Unzipping SDK3.1M5a, using an existing workspace and java project, when
attempting to do an ANT build using an ANT builder, or attempting to open
a build.xml file with the ANT file editor, Eclipse crashes with the
following output in my .log file:
!SESSION 2005-02-20 23:09:02.843
eclipse.buildId=I20050219-1500
java.version=1.5.0_01
Framework arguments: -showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 -clean -data
C:\DOCUME~1\bhoylman\HOME\Eclipse\workspace3.1M5a -showlocation
!SESSION Sun Feb 20 23:10:35 MST 2005
!ENTRY org.eclipse.core.launcher 4 0 Feb 20, 2005 23:10:35.968
!MESSAGE Exception launching the Eclipse Platform:
!STACK
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:167)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
This subsequently leaves an eclipse.exe and a javaw process orphaned as
well. I have tried a clean workspace with the project imported and the
same thing happens. This is NOT the case with build I20050202.
Ouch! Any comments welcome.
Peace.
Re: M5: java.lang.NoClassDefFoundError when doing ANT stuff [message #196347 is a reply to message #196339] Mon, 21 February 2005 02:01 Go to previous messageGo to next message
This time I took a fresh M5a with NO workspace pre-existing. I imported a
small existing project that contained a build.xml file. Attempting to
open the file yielded this following log:
!SESSION 2005-02-20 23:57:10.250
C:\DOCUME~1\bhoylman\HOME\Eclipse\workspaceTEST -showlocation
!ENTRY org.eclipse.ui 4 4 2005-02-20 23:57:10.250
!MESSAGE Could not create action delegate for id:
org.eclipse.ui.edit.text.openExternalFile
!SESSION Sun Feb 20 23:57:10 MST 2005
!ENTRY org.eclipse.core.launcher 4 0 Feb 20, 2005 23:57:10.296
!STACK
Note this log mentions something about an action delegate, which is
something i didn't see in my earlier log posting. Thought it might be a
bit more information to ponder.
Thanks again.
Peace.
Re: M5: java.lang.NoClassDefFoundError when doing ANT stuff [message #196379 is a reply to message #196339] Mon, 21 February 2005 06:30 Go to previous messageGo to next message
Originally posted by: u.pollaehne12.web.de
Hi Bruce,
I found the same issue:
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=85942>
Ullrich.
Re: M5: java.lang.NoClassDefFoundError when doing ANT stuff [message #196434 is a reply to message #196379] Mon, 21 February 2005 12:27 Go to previous messageGo to next message
I am having no luck using bugzilla this morning.
I believe you are specifying -Xverify:none when running Eclipse?
This is causing problems with the Ant security manager created for bug
60860. This appears to be a duplicate of
https://bugs.eclipse.org/bugs/show_bug.cgi?id=85908
HTH
Darins
"Ullrich Pollaehne" <u.pollaehne12@web.de> wrote in message
news:cvcgqb$h95$1@www.eclipse.org...
> Hi Bruce,
> Ullrich.
Re: M5: java.lang.NoClassDefFoundError when doing ANT stuff [message #196461 is a reply to message #196434] Tue, 22 February 2005 06:47 Go to previous messageGo to next message
Hi Darin,
yeah, you got me. ;-)
After removing -Xverify:none ANT worked as expected.
Is there a chance to get a M5b?
Ullrich.
Re: M5: java.lang.NoClassDefFoundError when doing ANT stuff [message #196482 is a reply to message #196461] Tue, 22 February 2005 10:32 Go to previous message
news:cvf666$hqb$1@www.eclipse.org...
> Hi Darin,
> Ullrich.
No this will not cause an M5b.
You options are:
to not specify -Xverify:none
to make use of the integration build that will come out today where the
problem is fixed
to patch the org.eclipse.ant.core plugin of M5a with the one that comes out
in the integration build of today.
HTH
Darins
Previous Topic:Is this a eclipseM5 bug?
Next Topic:Hyperlink style navigation to a runtime implemented method
Current Time: Sat Apr 19 22:22:42 EDT 2025
Powered by FUDForum. Page generated in 0.03765 seconds
