Home » Archived » BIRT » javadoc online?
javadoc online? [message #195701] Mon, 16 October 2006 11:29 Go to next message
I try to integrate BIRT into our framework. BIRT is
a component, its html ouput is integrated into JSF page.
I need to pass parameter from URL into IRunAndRenderTask.
I didn't find it in http://www.eclipse.org/birt/phoenix/deploy/#reportAPI
so I looked for javadoc - it is not online. I have to
download BIRT SDK to access it :-(
1) please add this information about parameters into Integration
page
2) upload javadoc online, it is a good habbit of most open source
projects
Leos
Re: javadoc online? [message #195793 is a reply to message #195701] Mon, 16 October 2006 13:27 Go to previous messageGo to next message
All the Javadocs are available in the online help for BIRT.
Open the Help Contents. Open the BIRT Programmer's reference and the
Javadocs are included.
Jason
"Leos Literak" <literakl@centrum.cz> wrote in message
news:eh08hb$2l5$1@utils.eclipse.org...
> page
> projects
> Thanks
> Leos
Re: javadoc online? [message #195893 is a reply to message #195793] Tue, 17 October 2006 03:55 Go to previous messageGo to next message
Jason,
that does not work for me. When I click on this topic in Help Contents,
SWT error occurs and it instructs me to shut down eclipse.
Nevertheless even if it worked, I don't find it as sufficient. What is
the problem with having javadoc online? Why do I have to download complete
BIRT installation to look for one method's javadoc?
I don't use eclipse as my Java IDE, so I'd prefer to have separate
javadoc independant of Eclipse. It is really useful when javadoc is
online, even google can index it.
I downloaded SDK but it is hard to find it there. It is full of plugins
with long names, that are hard to guess their purpose for newbies.
I found BIRT help in:
plugins/org.eclipse.birt.doc_2.1.1.v20060921-1226/doc.zip
Javadoc is in
plugins/org.eclipse.birt.doc.isv_2.1.1.v20060921-1226/doc.zi p
Could you at least write into README of SDK that users can find it
there?
Leos
Jason Weathersby napsal(a):
> Jason
>> page
>> projects
Re: javadoc online? [message #195901 is a reply to message #195893] Tue, 17 October 2006 04:19 Go to previous messageGo to next message
Originally posted by: ratz._NOSPAM_drugphish.ch
Leos,
I'll chime in since you seem to be a bit impatient and the US guys are
still mostly asleep.
That's rather bad.
Would following documentation be enough for you?:
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. birt.doc/model/api/index.html
To me it seems that the whole BIRT API is referenced there in javadoc
format, publicly.
Is there some other documentation besides the whole Eclipse and Birt API
you're missing? The Java language API can be found via:
http://java.sun.com/reference/api
But I'm sure you knew that.
That is true.
> Javadoc is in
This is IMHO the ROM, to be found at the first reference I gave you above:
> there?
Which README are you referring to exactly?
Your initial question to my avail has only little to do with BIRT, but
rather with how to handle URI parsing from within Servlet Context.
There's huge amount of excellently written material in the Internet:
http://www.coreservlets.com/
https://bpcatalog.dev.java.net/nonav/ajax/textfield-jsf/desi gn.html
To me, your problem sounded like you just need to get the correct
parameters passed within the request, like so:
String var = request.getParameter("passed_var");
I might be completely mistaken regarding your problem, but then you
probably should re-formulate your problem or wait for someone to
understand your question.
HTH and best regards,
Roberto Nibali, ratz
echo
'[q]sa[ln0=aln256%Pln256/snlbx]sb313507179010176854228757843 9snlbxq' | dc
Re: javadoc online? [message #195944 is a reply to message #195901] Tue, 17 October 2006 06:58 Go to previous messageGo to next message
Roberto Nibali napsal(a):
I know, Roberto :-) But I write emails in my timezone, they can wait
till USE guys wake up. ;-)
cool, that is what I searched for. Where did you find this link?
I thought that I have already visited most of BIRT pages, though I didn't
find it.
> format, publicly.
you are right, perfect!
I was talking about BIRT's javadoc, not JDK javadoc
>> Javadoc is in
I can find complete javadoc in those zip files.
>> there?
birt-report-framework-sdk-2_1_1.zip contains directory eclipse
with sub directories features and plugins and two files:
epl-v10.html and notice.html. So actually you are right - there is
no README at all :-(
As a newbie I didn't know, what to do with this file. I guess that
it shall be copied to eclipse installation, shall not it?
> http://www.coreservlets.com/> I might be completely mistaken regarding your problem, but then you
Well, you are right. I didn't seek help for my initial problem,
so I was quite lazy to describe it perfectly. My report requires
a parameter id to be set. I embed BIRT into our JSF page, so I
have to pass HTTP request parameter to BIRT ReportEngine myself.
This page http://www.eclipse.org/birt/phoenix/deploy/reportEngineAPI.p hp
does not deal with parameter passing to report engine. So I had to
find javadoc to see available methods and finally I wrote following
code, which works:
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
task.setParameterValue(key, value);
It would be great, if this use case is covered by Report Engine API
page.
Sincerrelly
Leos
Re: javadoc online? [message #195961 is a reply to message #195944] Tue, 17 October 2006 08:55 Go to previous message
Hello Leos,
http://www.google.cz/search?hl=cs&q=birt+api+documentati on&btnG=Vyhledat+Googlem&lr=
And then I clicked on the first link :).
> find it.
The BIRT homepage is violating the principle of software ergonomics in
GUI design, that's probably why. To me one of the big missing points on
the entry page (http://www.eclipse.org/birt/phoenix/) is a documentation
section, which consist of
1. Users documentation (Installation, FAQ and forth)
2. Developers documentation (Reference, Examples, API, Wiki and forth)
The Navigation Menu should not consist of more than 9 elements,
normally. But this is all off-topic, possibly interesting read-up on:
http://www.webstyleguide.com/index.html
>> format, publicly.
>> API you're missing? The Java language API can be found via:
>>> Javadoc is in
>> above:
I'm perfectly content with the online API documentation, so the
documentation found somewhere in the sources is of no interest to me.
>>> there?
Where you expecting one?
Which file are you referring to?
>> your problem, but then you probably should re-formulate your problem
>> or wait for someone to understand your question.
That is correct and Jason has mentioned that this part of the
documentation shall be updated, as soon as he finds time. When I first
searched for this I found following helpful documentation (in this order):
http://wiki.eclipse.org/index.php/Simple_Execute
http://marklorenz.blogspot.com/2006/03/more-birt-tips-for-ja va-developers.html
http://marklorenz.blogspot.com/2006/02/birt-tips-for-java-de velopers.html
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. birt.doc/engine/api/org/eclipse/birt/report/engine/api/IEngi neTask.html
> So I had to
> code, which works:
Alternatively you can create a HashMap of parameters and pass them via
the following call:
task.setParameterValues(params)
That's what I use for example to pass the parameters HashMap I get from
the OpenReports framework to the BIRT engine for rendering. Works like a
charm. For some (not yet understood and decided) motivation I also add
following call after the set-method:
task.validateParameters();
I have absolutely no clue what this actually does and from the
documentation I gather:
public boolean validateParameters()
Returns:
whether the parameter validation succeeds
Aha, and then reading the source code leaves me absolutely clueless:
public boolean validateParameters( ) {
if (runnable == null) {
return false;
// set the parameter values into the execution context
usingParameterValues( );
// validate each parameter to see if it is validate
????? I tried really hard to understand this ...
return new ParameterVisitor( ) {
boolean visitScalarParameter( ScalarParameterHandle param, Object
value ) {
return validateScalarParameter( param );
boolean visitParameterGroup( ParameterGroupHandle group, Object
value ) {
return visitParametersInGroup( group, value );
}.visit( (ReportDesignHandle) runnable.getDesignHandle( ), null );
Even when skimming over the call-chain; I was definitely amused by the
code comment regarding validation, though :). So I'd also welcome some
information on this.
> page.
Fully agreed on my part.
echo
Previous Topic:Help on Exception
Next Topic:dataset paging?
Current Time: Sun Sep 14 05:07:49 EDT 2025
Powered by FUDForum. Page generated in 0.03823 seconds
