Home » Language IDEs » C / C++ IDE (CDT) » How to build projects using specified gcc
How to build projects using specified gcc [message #195075] Wed, 04 July 2007 01:47
Originally posted by: chenal.naritech.cn
I have installed gcc-4.1.0 on openSUSE 10.2 and it is the default gcc
compiler. Because we want to develop software used on real time Linux
where gcc version is 3.4.1. So I downloaded and built gcc-3.4.1. It is
installed in /usr/local/gcc-3.4.1. And in the /usr/bin, I create links:
$ ln -s /usr/local/gcc-3.4.1/bin/gcc gcc-3.4
$ ln -s /usr/local/gcc-3.4.1/bin/g++ g++-3.4
In my CDT Managed C++ project, I add another two build configurations:
Debug-3.4
Release-3.4
And set command to be g++-3.4 in the properties->C/C++ build->Tool
Settings->GCC C++ Compiler, and add /usr/local/gcc-3.4.1/include to GCC
C++ Compiler->Diectories.
I wonder whether it is right to do like this?
After I build the project, the compiler tells a warning:
Warning: libstdc++.so.5, need by /home/test/libipc.so, may conflict with
libstdc++.so.6
How to avoid this warning?
Please help me. Thank you very much.
Regard
Allen Chen
Previous Topic:Problem with detection of Cygwin
Next Topic:"The CPU is not supported by selected debugger"
Current Time: Mon Sep 15 21:04:15 EDT 2025
Powered by FUDForum. Page generated in 0.07151 seconds
