Home » Archived » BIRT » How would I do this using the Birt Charting Engine API?
How would I do this using the Birt Charting Engine API? [message #192861] |
Wed, 27 September 2006 14:03 |
Originally posted by: mrmikeolson.yahoo.ca
I would like to have the bar labels in a chart to be the series name,
but the mouseover tooltips to be the value of the bar.
By default, the label is the value, but I was told I could change the
label the series name like so:
bs1.getDataPoint( ).getComponents( ).clear( );
bs1.getDataPoint( ).getComponents( ).add( DataPointComponentImpl.create(
DataPointComponentType.SERIES_VALUE_LITERAL, null ) );
This works fine, however, when I create my tooltips, I do it like so:
bs1.getTriggers( ).add(
TriggerImpl.create(
TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create(
ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create(500,
bs1.getLabel().getCaption().getValue() )
Which, of course gives me the series name as a tooltip instead of a
value. How would I put the bar value in the tooltip instead?
Re: How would I do this using the Birt Charting Engine API? [message #192942 is a reply to message #192861] |
Wed, 27 September 2006 18:14 |
David Michonneau Messages: 1145 Registered: July 2009 |
Just leave the tooltip value empty. It should automatically pick up the
value.
David
"molson" <mrmikeolson@yahoo.ca> wrote in message
news:efe0ar$jga$1@utils.eclipse.org...
>I would like to have the bar labels in a chart to be the series name, but
> TriggerImpl.create(
> ActionImpl.create(
> Which, of course gives me the series name as a tooltip instead of a value.
Re: How would I do this using the Birt Charting Engine API? [message #192981 is a reply to message #192942] |
Wed, 27 September 2006 20:54 |
If I do this:
TriggerImpl.create(
ActionImpl.create(
TooltipValueImpl.create(500, "" )
I still get the series name as the tooltip, not the bar value.
Am I missing something here?
> value.
> David
>> TriggerImpl.create(
>> ActionImpl.create(
Re: How would I do this using the Birt Charting Engine API? [message #193092 is a reply to message #192981] |
Thu, 28 September 2006 09:21 |
Try with null instead of "", it should normally work.
David
news:efeoe2$ifg$1@utils.eclipse.org...
> If I do this:
> TriggerImpl.create(
> ActionImpl.create(
>> value.
>> Thanks,
>> David
>>> TriggerImpl.create(
>>> ActionImpl.create(
Current Time: Wed Sep 18 14:02:43 GMT 2024
Powered by FUDForum. Page generated in 0.03621 seconds
