Creating an RCP [message #192636] |
Sat, 14 June 2008 15:40 |
Originally posted by: davidmusat.hotmail.com
Hello everybody,
I'm creating an RCP and I've some problems with it. I have been
following the 4th GMF tutorial but with another application instead of
mindmap. I've developed the Eclipse application without problems, but
now I want to create a rich client platform. I've been following all the
instructions and I've generated the .diagram without errors, but then,
when I try to paint with drug and drop in my diagram, it doesn't work.
Everything is aparently all right, but it isn't.I can't find the clue.
Can anybody help me?
Thank you in advanced
Regards.
DAVID MUSAT SALVADOR
Re: Creating an RCP [message #192772 is a reply to message #192636] |
Mon, 16 June 2008 07:58 |
Originally posted by: martinschmidt.83.web.de
Hi David,
for me it sounds not like a RCP problem. I would suggest generating as
non-RCP and check the editors behaviour. If the same problem appear, your
..gmfmap-file seems to be incorrect ;)
Regards, Martin
"David Musat" <davidmusat@hotmail.com> schrieb im Newsbeitrag
news:g30olu$leh$1@build.eclipse.org...
> Hello everybody,
> I'm creating an RCP and I've some problems with it. I have been following
> the 4th GMF tutorial but with another application instead of mindmap. I've
> developed the Eclipse application without problems, but now I want to
> create a rich client platform. I've been following all the instructions
> and I've generated the .diagram without errors, but then, when I try to
> paint with drug and drop in my diagram, it doesn't work. Everything is
> aparently all right, but it isn't.I can't find the clue. Can anybody help
> me?
> Regards.
Re: Creating an RCP [message #192970 is a reply to message #192772] |
Mon, 16 June 2008 16:35 |
I've created a non_RCP and it worksd properly, but when I try with an
RCP it doesn' work,waht can I do?
Martin Schmidt escribió:
> Hi David,
> Regards, Martin
>> Hello everybody,
>> me?
>> Regards.
FUDForum. Page generated in 0.04266 seconds
