Home » Language IDEs » C / C++ IDE (CDT) » how to build a project when Makefile is in subdirectory?
how to build a project when Makefile is in subdirectory? [message #192119] Wed, 30 May 2007 01:07 Go to next message
Hello everyone,
I'm kind of new to Eclipse and I am facing a problem with a project that I
imported from my CVS repository as a standard make c++ project (as the
tutorial explained). The project has a Makefile that I created, but it is
not in the root directory but on the src/ subdirectory. Now, when I try to
build the project, nothing happens of course because there is no Makefile
in the root directory. Is there a way to tell Eclipse to run make in a
subdirectory?
Thanks for your help.
a^2
Re: how to build a project when Makefile is in subdirectory? [message #192125 is a reply to message #192119] Wed, 30 May 2007 03:12 Go to previous messageGo to next message
Originally posted by: dmsubs.NOSPAM.consertum.com
Either:
- change the make command in Eclipse to make -C subdirectory
- add a makefile in the project root that invokes make in the subdirectory
Derek
Alejandro Aragón wrote:
> Hello everyone,
> I imported from my CVS repository as a standard make c++ project (as the
> is not in the root directory but on the src/ subdirectory. Now, when I
> try to build the project, nothing happens of course because there is no
> Makefile in the root directory. Is there a way to tell Eclipse to run
> make in a subdirectory?
> a^2
Re: how to build a project when Makefile is in subdirectory? [message #192195 is a reply to message #192125] Wed, 30 May 2007 13:39 Go to previous messageGo to next message
Derek Morris wrote:
> Either:
I did it the first way and it works fine!
Do you have an example of a Makefile that calls other Makefiles in
subdirectories? I don't really understand how Makefiles work.
Thank you.
Re: how to build a project when Makefile is in subdirectory? [message #192237 is a reply to message #192195] Wed, 30 May 2007 15:42 Go to previous messageGo to next message
Here is a really simple example:
DIRS=sub-dir1 sub-dir2 sub-dir3
all::
@for i in ${DIRS}; \
do \
make -C $${i}; \
done
clean::
do \
make -C $${i} clean; \
done
HTH
Derek
> Derek Morris wrote:
>> Either:
>> subdirectory
> Thank you.
Re: how to build a project when Makefile is in subdirectory? [message #192300 is a reply to message #192195] Thu, 31 May 2007 04:07 Go to previous messageGo to next message
If make is available on your system the documentation is probably
available too in info pages. Just call "info make" or use another
info browser.
Please note that Makefiles are not only useful for compilation but
also to create other files which have dependencies such as
documentation, ... So you should really learn it.
Jens
Re: how to build a project when Makefile is in subdirectory? [message #192415 is a reply to message #192119] Fri, 01 June 2007 12:09 Go to previous messageGo to next message
> subdirectory?
You can specify the build directory:
Goto project->properties->C/C++ Make Project->Build Location->Build
directory
Click the button Workspace below the text field. Select the subdirectory
where your Makefile resides.
Re: how to build a project when Makefile is in subdirectory? [message #192446 is a reply to message #192415] Sat, 02 June 2007 18:58 Go to previous messageGo to next message
>> subdirectory?
> directory
This is a nice way to do it. The funny thing is that this option (build
directory) was hidden in the window that pops-up after
Project->Preferences. I had to resize that windows for that option to
appear. I'm using Eclipse 3.2.2 on an Ubuntu Linux platform. Is this a bug?
Thanks for helping.
a^2
Re: how to build a project when Makefile is in subdirectory? [message #192710 is a reply to message #192195] Wed, 06 June 2007 15:37 Go to previous messageGo to next message
Originally posted by: guyen000.gmail.com
simple one, this may work.
all:
./$(YOUSUBDIR)/make all
Make sure there is a tab, not spaces before command
Re: how to build a project when Makefile is in subdirectory? [message #192910 is a reply to message #192446] Fri, 08 June 2007 10:13 Go to previous message
I never had that problem. I am using Eclipse 3.2.2 on Gentoo with Sun JRE
1.5 (JRE 1.4 and 1.6 also work flawless).
Axel
Previous Topic:CVS Server information
Next Topic:Solaris CC compiled code debug with gdb 5.3
Current Time: Sat Apr 26 00:36:24 EDT 2025
Powered by FUDForum. Page generated in 0.03003 seconds
