Home » Eclipse Projects » Subversive » Slow renaming/moving/deleting
Slow renaming/moving/deleting [message #18262] Mon, 05 May 2008 22:09 Go to next message
Eric Jain is currently offline Eric JainFriend
Renaming or moving or deleting a directory that contains a few dozen files
totaling maybe a few megabytes seems to take orders of magnitudes (i.e. up
to a minute or longer) longer than doing the same operation on the file
system (even if you were to create backup copies of all affected files).
Is this to be expected? Moreover, while the operation is running, a modal
dialog is shown, so you can't do anything else...
Re: Slow renaming/moving/deleting [message #18296 is a reply to message #18262] Tue, 06 May 2008 07:33 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Eric,
Could you please specify what SVN connector you use? (you can check it at
Window->Preferences->Team->SVN->SVN Connector).
Re: Slow renaming/moving/deleting [message #18348 is a reply to message #18296] Tue, 06 May 2008 16:39 Go to previous messageGo to next message
SVN Kit 1.2.0 r4104
Re: Slow renaming/moving/deleting [message #18364 is a reply to message #18262] Tue, 06 May 2008 22:28 Go to previous message
Should add to this that committing these directory changes takes even
longer (up to half an hour!). Lots of time seems to be spent with:
Commit
Clear Update Statuses Cache: [Running...]
Previous Topic:svn properties borked?
Next Topic:Duplicate repository locations created on import of Team Project Set
Current Time: Thu Dec 26 17:38:52 GMT 2024
Powered by FUDForum. Page generated in 0.03243 seconds
