Home » Language IDEs » Java Development Tools (JDT) » JDT automatic source annotation *date format*
JDT automatic source annotation *date format* [message #192102] |
Sun, 09 January 2005 23:58 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: natgross.rentalsystems.verizon.net
Hi;
On a WinXP platform, with Eclipse 3.0.1, although I have my Regional
settings set to US, the automatic ${date} that gets inserted in my code
is European format.
I have searched thru the preferences and failed to find where I can
adjust this to get the US format.
Please advise;
Thank you;
-nat
Re: JDT automatic source annotation *date format* [message #192200 is a reply to message #192185] |
Mon, 10 January 2005 19:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Tom Eicher wrote:
> Nat Gross wrote:
>> Hi;
>> code is European format.
> You mean the ${date} in the default file template?
Yes.
>It is the output of
>return DateFormat.getDateInstance().format(new java.util.Date());
Hey. Never noticed that since I use a per-locale formatter in my code.
You are correct though, that this line of code returns European style
for me.
> so I assume you have set your locale to european style somewhere.
It's the million dollar question. Where? My XP Region is set to US.
I might have to resort to start Eclipse with a jvm parameter to set
locale, but hesitate to do so, because portions of my code is locale
specific, and I don't want the jvm parameter to 'confuse' the code.
Hopefully this fear is unfounded, and since I do not know what's causing
the Euro style date (maybe a hangover of a Windozzz crash), I should
just set the Eclipse's startup jvm's locale?
> -tom
Thank you much;
-nat
Re: JDT automatic source annotation *date format* [message #192243 is a reply to message #192200] |
Tue, 11 January 2005 10:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: zoopy.hates.spam.biz
On 10-1-2005 20:01, Nat Gross wrote:
> Tom Eicher wrote:
>> Nat Gross wrote:
>>> Hi;
> Yes.
>> It is the output of return DateFormat.getDateInstance().format(new
>> java.util.Date());
> for me.
>> -tom
> Thank you much;
> -nat
You can use the '-nl' parameter to the Eclipse executable. See
Help/Workbench User Guide/Tasks/Running Eclipse. E.g. with the Dutch
locale nl_NL:
"C:\Program Files\Eclipse\eclipse.3.0.1\eclipse\eclipse.exe" -nl nl_NL
-vm "C:\Program Files\Java\j2re1.4.2\bin\javaw.exe" -vmargs -Xmx192m
This produced the following date comment in a newly created class:
* <code>DateLocaleTest</code>
* @author SmithZ
* @created 11-jan-2005
Using '-nl en_US', it produced:
* <code>DateLocaleTest2</code>
* @author SmithZ
* @created Jan 11, 2005
In 'Help/About Eclipse Platform/Configuration details' you can verify
the locale used by the JVM. Even with the parameter '-nl nl_NL' I see
user.country=US
user.language=en
but also
osgi.nl=nl_NL
HTH,
Z.
Re: JDT automatic source annotation *date format* [message #192258 is a reply to message #192243] |
Tue, 11 January 2005 15:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
>> Tom Eicher wrote:
>>> Nat Gross wrote:
>>>> Hi;
>> Yes.
>>> java.util.Date());
>> for me.
>> causing the Euro style date (maybe a hangover of a Windozzz crash), I
>> should just set the Eclipse's startup jvm's locale?
>>> -tom
>> Thank you much;
>> -nat
> locale nl_NL:
> * @author SmithZ
> * @author SmithZ
> user.country=US
> user.language=en
> but also
> osgi.nl=nl_NL
> HTH,
The -nl did the trick. However, my concern is that strings within my
sources that are *not* en_US, should not become confused.
I would much rather prefer a simple setting in preferences for the date
format of dates inserted in my source.
Also, a little peculiar thing. Before I set it to en_US, the date was
Euro format, but with numbers (Jan 10 was 10/1/2005), now it is indeed
set to US, but not numbers, rather Jan 10, 2005 string. Just wondering...
Thanks;
-nat
Current Time: Wed Jul 17 12:41:12 GMT 2024
Powered by FUDForum. Page generated in 0.03529 seconds
