Shitty Tutorial! [message #192008] |
Sat, 08 January 2005 10:52 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: dsa..asdf.com
I have just downloaded eclipse 3.0.1.
In the Java Tutorial you are told to download: Example Plugin-ins
I have just done so, its called:
eclipse-examples-3.0.1-win32.zip
and its about 1.8 MB.
Then I have imported the files from the file-import-Zip file menu.
But when I look at my Package Explorer I don't see any of the JUnit files
that are displayed in
the tutorial. Instead I have:
eclipse
eclipse.features
eclipse.plugins
and under eclipse.plugin I have:
org.eclipse.compare.examples.xml_3.0.0
org.eclipse.compare.examples_3.0.0
org.eclipse.help.examples.ex1_3.0.0
org.eclipse.jdt.ui.examples.projects_3.0.1
org.eclipse.sdk.examples.source.win32.win32.x86_3.0.1
org.eclipse.sdk.examples.source_3.0.1
org.eclipse.sdk.examples_3.0.1
org.eclipse.swt.examples.browser_3.0.0
org.eclipse.swt.examples.controls_3.0.0
org.eclipse.swt.examples.launcher_3.0.0
org.eclipse.swt.examples.layouts_3.0.0
org.eclipse.swt.examples.ole.win32_3.0.0
org.eclipse.swt.examples.paint_3.0.0
org.eclipse.swt.examples_3.0.0
org.eclipse.team.examples.filesystem_3.0.0
org.eclipse.ui.examples.javaeditor_3.0.0
org.eclipse.ui.examples.multipageeditor_2.1.0
org.eclipse.ui.examples.propertysheet_2.1.0
org.eclipse.ui.examples.readmetool_2.1.0
What have I done wrong? Its the most crappy tutorial I have ever read! Used
2
Please reread the download page [message #192108 is a reply to message #192008] |
Mon, 10 January 2005 03:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Right above the download link for the eclipse-examples zip, you'll
see this:
"To install the examples, first make sure you have exited your
Eclipse program. Then download the zip file containing the examples
and extract the contents of the zip file to the same directory you
used for your SDK installation. For example, if you installed the
Eclipse Project SDK on d:\eclipse-sdk then extract the contents of
the examples zip file to d:\eclipse-sdk. Start Eclipse. The example
plug-ins will be installed. For information on what the examples do
and how to run them, look in the "Examples Guide" section of the
"Platform Plug-in Developer Guide", by selecting Help Contents from
the Help menu, and choosing "Platform Plug-in Developer Guide" book
from the combo box."
Don't import it into your workspace as that is not how you are meant
to install them.
- Nitin
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.03740 seconds
