Build problems [message #18252] |
Fri, 21 March 2008 13:16  |
Originally posted by: quentin.glineur.obeo.fr
--------------090703020901070208060601
Hi all,
I tried to build IMP on Eclipse 3.3 thanks to the patches in bug 221887.
As it is mentioned to use CVS head 20080221, I downloaded this date
version. -> Problems mainly because of no
org.eclipse.imp.lpg.metatooling/templates folder.
Therefore, I updated to the latest version from head.
I now have a problem of plugins dependencies. Several ones declare a
dependency to org.eclipse.imp.pdb (which I can't find) and
org.eclipse.imp.box declares a dependency to sdf_eclipse_installer
(which I also can't find).
Did I miss something ? Do any one have tips to build a IMP version on
3.3 (my final goal is to evaluate a possible coupling between a IMP IDE
and the MDT OCL framework)?
Thanks a lot.
Quentin
Content-Type: text/x-vcard; charset=utf-8;
name="quentin_glineur.vcf"
Content-Disposition: attachment;
filename="quentin_glineur.vcf"
begin:vcard
fn:Quentin GLINEUR
n:GLINEUR;Quentin
org:Obeo - Model Driven Company;Research and Development
adr;quoted-printable:;;2 rue Robert Schumann;Rez=C3=A9;;44400;France
email;internet:quentin.glineur@obeo.fr
title:MDA Consultant
tel;work:+332 51 13 54 18
x-mozilla-html:TRUE
url:http://www.obeo.fr
version:2.1
end:vcard
--------------090703020901070208060601--
Re: Build problems [message #18327 is a reply to message #18252] |
Tue, 25 March 2008 10:17  |
Quentin Glineur wrote:
> Hi all,
We're about to commit org.eclipse.imp.pdb. Not committing it before
was an oversight (obviously), but none of the plugins we actually
distribute as part of the IMP features depends on pdb, nor on box
or sdf_eclipse_installer. The latter two plugins are part of the
recent addition of source formatting support, which isn't yet part
of the IMP distribution. It's basically bleeding-edge code. :-)
To help get started with the IMP code base, we've put some
functionality in our "release engineering" tooling that will
retrieve the necessary source from the source repository using a
set of Team Project Sets (one per feature). I'll post here when
we've got that updated with the new SVN project locations.
Sounds cool. Keep us posted!
-- Bob
Robert M. Fuhrer
Research Staff Member
Programming Technologies Dept.
IBM T.J. Watson Research Center
IMP Team Lead (http://eclipse-imp.sourceforge.net)
X10: Productivity for High-Performance Parallel Programming (http://x10.sf.net)
Re: Build problems [message #570013 is a reply to message #18252] |
> Hi all,
-- Bob
Robert M. Fuhrer
FUDForum. Page generated in 0.06882 seconds
