Running command line argument file with Eclipse. [message #18126] |
Thu, 27 January 2005 05:15  |
Originally posted by: untz.hotmail.com
Suppose you write a program that's expecting a file (my situation is an
xml file), to be args[0] in your code... I know that I can build an Ant
build script, but what I am asking for is how do I set eclipse up so I
could run the file using "Run as Java Application"?
I keep getting: <usage> java myclassfile filename.xml in the console.
Does anyone understand what I am trying to get at?
Re: Running command line argument file with Eclipse. [message #19215 is a reply to message #18161] |
Thu, 27 January 2005 20:09  |
I tried that with a file prompt which pointed to the xml file and it still
doesn't work at runtime... How do you configure eclipse to always run the
standalone Java application (which includes the 'public static void main
(String args[])') to run against a args[0] file?
Also, what is the *BEST* XML plugin in the market for Eclipse?
Thanks for your help,
Unnsse
Jeff Myers wrote:
> Unnsse,
> In Eclipse, pull down the Run menu and choose Run... Select an existing
> run configuration for your Java Application or create a new one. Switch
> to the Arguments tab of the run configuration and add your arguments in
> the Program Arguments text box, and then press Run.
> Hope this helps,
> - Jeff
FUDForum. Page generated in 0.08704 seconds
