CDT Disassembly View [message #190917] |
Tue, 08 May 2007 11:37 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jonathan.orditz.selectron.ch
A disassembly view is provided by the CDT. But only the actual "module"
where the debugger is can be seen. Is it possible to see a disassembly
view for all the c-files in the project and in the libraries added to the
project (if sources are available of course...) ?
Because I want to go to adress 0x402ffe where I have a problem but I found
nothing (Context Menu, ....) to "jump" to this adress and I do not know
what code is located at this address.
Or do someone know if the GCC compiler can output a "list" file ? (in
order to know what module is located on my address). I found nothing in
the documentation of GCC...
Many thanks in advance...
Jonathan
FUDForum. Page generated in 0.03491 seconds
