Home » Eclipse Projects » GEF » Poll: Articles to be written on using GEF
Poll: Articles to be written on using GEF [message #18062] Mon, 26 August 2002 20:04 Go to next message
Originally posted by: hudsonr.spam.com
I would like to take a poll to know which subjects should be covered first
in our reference section. Examples might include:
Creating connections in GEF
Using the Platform (SWT) Drag and Drop support w/GEF
How to extend keyboard support in GEF
Using "Direct Edit" in GEF
Creating complex figures in draw2d
Re: Articles to be written on using GEF [message #18075 is a reply to message #18062] Tue, 27 August 2002 01:41 Go to previous messageGo to next message
Originally posted by: g.wagenknecht.intershop.de
"Randy Hudson" <hudsonr@spam.com> schrieb im Newsbeitrag
news:akef2p$k57$1@rogue.oti.com...
I would like to have more information about this. I don't have an idea how
this could be realized today.
Thanks, Gunnar
Re: Articles to be written on using GEF [message #18105 is a reply to message #18075] Tue, 27 August 2002 10:59 Go to previous messageGo to next message
Please describe what you consider to be a complex figure. I was thinking of
things like a UML class (with title, attributes, and operations), or a Node,
consisting of an Image, Text, and multiple decorations on the Image. The
"take home message" would be that you should avoid overriding validate() or
setBounds() on your figure, and maybe how to avoid coupling between the
figure and editpart/model.
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:akf2s2$qvm$1@rogue.oti.com...
> Thanks, Gunnar
Re: Articles to be written on using GEF [message #18349 is a reply to message #18105] Wed, 28 August 2002 10:01 Go to previous messageGo to next message
Hi!
news:akg3i1$dbh$1@rogue.oti.com...
of
I was thinking of a complex draw2d figure with a vector figure in mind and
the possibility to draw manifold shapes.
Cu, Gunnar
Re: Poll: Articles to be written on using GEF [message #19188 is a reply to message #18062] Mon, 09 September 2002 17:07 Go to previous messageGo to next message
Here are two suggestions:
1) How to properly subclass Figure.
2) Subclassing Figure for use in GEF diagrams.
But before you do that, completed Javadoc would also be greatly
appreciated. For example, from ImageCache:
checkout
public static Image checkout(Dimension d,
Object o)
Returns an image that is at least as big as the desired size. NOTE: (1)
The client should not dispose the image that is checked out (2) However,
the client should check the image back in when done (3) The given
dimension will not be modified by this method (4) The client should not
use the returned image's bounds for anything (since the returned image
could be bigger than requested) (5) If the size of the image is too big,
and the image cannot be created, this method will return null
Parameters:
d - The desired size of the image to be checked out
This is a pretty nice entry, however, what is the Object o parameter
used for? This Javadoc entry is frustrating for two reasons: (1) @param
o isn't documented at all (2) @param o's name is not meaningful.
Thanks in advance,
Dave
Dave Orme
Advanced Systems Concepts
http://www.asc-iseries.com
Re: Poll: Articles to be written on using GEF [message #19318 is a reply to message #19188] Tue, 10 September 2002 10:29 Go to previous messageGo to next message
Thanks for the suggestions.
I understand your frustration. We are working on this whenever we can.
org.eclipse.draw2d.util package is not exported by the plugin. We should
rename this package to internal.
Re: Poll: Articles to be written on using GEF [message #19410 is a reply to message #19318] Tue, 10 September 2002 12:35 Go to previous messageGo to next message
Randy Hudson wrote:
> <<snip>>
Glad to help!
Thanks for understanding.
Thanks for letting me know...
Dave
Dave Orme
Re: Articles to be written on using GEF [message #19501 is a reply to message #18062] Wed, 11 September 2002 05:59 Go to previous message
Originally posted by: amode.arrakis.es
That articles are OK ! But I think it would be interesting for the beginners
in GEF like me to write a small tutotial about building a graphical editor
with GEF step by step. It isn't necessary the example editor be complex. If
this tutorial exists now, please tell me where it is.
Thank you !
Previous Topic:Draw2d: Drawing Image in Thumbnail yelds NullPointerException
Next Topic:Commercial graphical product using SWT?
Current Time: Thu Sep 18 19:00:47 EDT 2025
Powered by FUDForum. Page generated in 0.04030 seconds
