Better template.php ? [message #18057] |
Tue, 14 November 2006 03:52 |
Michal Chmielewski Messages: 58 Registered: July 2009 |
Member |
So ... the basic template for generating pages in projects using this
php Phoenix magic looks like this:
--- snip -----
<?php ## The "require" magic is "off-screen"
# Begin: page-specific settings. Change these.
$pageTitle = "Sample Phoenix web page using the new templates";
$pageKeywords = "Type, page, keywords, here";
$pageAuthor = "Type your name here";
# Add page-specific Nav bars here
# $Nav->addCustomNav("My Link", "mypage.php", "_self", 3);
# $Nav->addCustomNav("Google", "http://www.google.com/", "_blank", 3);
# Paste your HTML content between the EOHTML markers!
$html = <<<EOHTML
html goes here.
EOHTML;
# Generate the web page
$App->generatePage($theme, $Menu, $Nav, $pageAuthor, $pageKeywords,
$pageTitle, $html);
--- snip -----
I am not very familiar with PHP but the $html = <<< EOHTML line is
really making the HTML content be buried in the PHP code. This is bad
for 2 reasons:
1) I can't use simple PHP include(file) directive to include content
that I may need in more then 1 place.
2) The PHPEclipse editor syntax highlighting is completely shot for the
HTML that is buried in the PHP code.
I read a little about output buffering in PHP and this template seems
more logical to me and fixes these 2 issues.
Changes have the <-- comment next to them
--- snip -----
<?php ## The require magic is "off-screen"
ob_start(); # <-- turns on buffering
# <-- now close the PHP code section
HTML goes here. PHPEclipse will nicely hilite the syntax because now it
knows that it is in the "html" area and give me HTML templates as I need
them via code assist.
You can do also things like <?= $pageAuthor ?> which are PHP escapes for
expressions.
You can also include pages such as ...
<?php include("some.page.html") ?>
<?php
# Generate the web page.
# <-- ob_get_clean() will get the currently produced output which
# <-- sits in the buffer and erase the buffer so that
# <-- App->generatePage() can do the chrome around the page content
$pageTitle, ob_get_clean() );
--- snip -----
This is working locally, on local.eclipe.org installation, and I presume
that it should work on Eclipse.org once checked in. However, there may
be some php configuration parameters that may not be set in the same way.
Anything that I am missing ?
-michal
FUDForum. Page generated in 0.04661 seconds
