Re: One diagram per file with an unsynchronized model [message #189312 is a reply to message #188742] |
Mon, 26 May 2008 11:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jan.herriger.gmx.de
You could generate your editor with 'synchronized' set to true. Then,
modify generated CEP:
1) getSemanticChildrenList():
This is the list of element types, which will be created, if there is no
corresponding view. Return an empty list here.
2) isOrphaned(...):
Replace method body with
return MyDiagramUpdater.isShortcutOrphaned(view);
This way, views are removed automatically. But view creation is still up
to the user. Connections are still fully synchronized. But, there are
two more things to consider:
DeleteFromDiagramAction won't let you delete views. It checks, if the
parent is canonical. Which is true, because there is a canonical edit
policy installed. You have to write your own action, which ignores CEPs.
Add this action inside generated ContributionItemProvider. Inside
Plug-in manifest, remove predefined 'deleteFromDiagramAction' (if
exists) and declare your own.
Last thing is: pressing 'del' will delete both, view and semantic
element. To prevent this, you can install a modified ComponentEditPolicy
inside your edit parts:
installEditPolicy(EditPolicy.COMPONENT_ROLE, new ComponentEditPolicy() {
protected boolean shouldDeleteSemantic() {
return false;
May be, there are other/better solutions. But it works for me. Since I'm
still using 2.0, I wonder if there were any changes in GMF 2.1 regarding
the synchronization behavior?
Jan
Sylvain Dudoit schrieb:
> Thx Alex, I will debug to understand this point.
> What about the way to update old diagrams by removing useless views ?
> Could you give me some help to understand how I could implement a kind
> of CanonicalEditPolicy ?
> Sylvain
> Alex Shatalin wrote:
>>> Do you know how I could mark the View with cross to avoid this
>>> behaviour ?
>> Well, isSetElement() should return true if setElement() was called for
>> this View instance. This means, in your situation all the elements
>> should be set AFAIU..
>> So, I suggest you to debug this method in case you have "cross" and
>> you have no "cross" and compare these two situations. As a result
>> you'll be able to find a reason of this problem.
Re: One diagram per file with an unsynchronized model [message #190655 is a reply to message #190613] |
Tue, 03 June 2008 12:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Sylvain,
this should be explained somewhere. But I don't know where right know.
This contributes your own action for a specific edit part and removes a
predefined one:
<extension point="org.eclipse.gmf.runtime.common.
ui.services.action.contributionItemProviders">
<?gmfgen generated="false"?>
<contributionItemProvider
class="yourPackage.diagram.providers.XxxContributionItemProvider "
checkPluginLoaded="false">
<Priority name="Low"/>
<popupContribution class="org.eclipse.gmf.runtime.diagram.ui.
providers.DiagramContextMenuProvider">
<popupStructuredContributionCriteria
objectClass="yourPackage.diagram.
edit.parts.XxxEditPart"/>
<popupAction
id="deleteFromDiagramAction"
path="/editGroup">
</popupAction>
<popupPredefinedItem
remove="true">
</popupPredefinedItem>
</popupContribution>
Your contribution provider should look like this:
protected IAction createAction(String actionId,
IWorkbenchPartDescriptor partDescriptor) {
if (actionId.equals(PrintPreviewAction.ID)) {
return new RenderedPrintPreviewAction(
new EnhancedPrintActionHelper());
} else if (actionId.equals(ActionIds.ACTION_DELETE_FROM_MODEL)) {
IWorkbenchPage workbenchPage = partDescriptor.getPartPage();
return new DeleteFromModelAction(workbenchPage);
} else if (actionId.equals(ActionIds.ACTION_DELETE_FROM_DIAGRAM)) {
return new DeleteFromDiagramAction(workbenchPage);
return super.createAction(actionId, partDescriptor);
Seems like I have my own delete from model action too... but I don't
remember why ;-)
btw: you don't use 'org.eclipse.ui.popupMenus' extension point here.
> Hi Jan,
> Thank you so much for your help !
> I have applied your indications with sucess. Well, I didn't found the
> method "isShortcutOrphaned(view)" in my generated "DiagramUpdater" but
> I've replaced it with a home-made one which checks for model element
> validity.
> For now, with a small example, it seems to work.
> My last problem is how to replace the DeleteFromDiagramAction inside
> The only way I've seen in this forum to add a custom action in the
> contextual menu is to contribute to the extension
> "org.eclipse.ui.popupMenus" as usual and to specify the selected item to
> " org.eclipse.gmf.runtime.diagram.ui.editparts.IGraphicalEditP art ".
> Could you give me more details about the way to add a custom action ? If
> this information is explained somewhere, could you simply copy/paste the
> URL ?
> Sylvain
Re: One diagram per file with an unsynchronized model [message #196051 is a reply to message #190655] |
Tue, 08 July 2008 09:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: janiko.gmx.de
Hi, i applied your solution successfully, thanks a lot. But the
contributionItemProviders extension pint dont have any effect. The
yourPackage.diagram.providers.XxxContributionItemProvider is never
called. May you or anyone else can help me here.
Jan Herriger schrieb:
> Hi Sylvain,
> predefined one:
> <popupAction
> path="/editGroup">
> </popupAction>
> remove="true">
> remember why ;-)
>> Hi Jan,
>> validity.
>> to " org.eclipse.gmf.runtime.diagram.ui.editparts.IGraphicalEditP art ".
>> If this information is explained somewhere, could you simply
>> copy/paste the URL ?
>> Thanks,
>> Sylvain
FUDForum. Page generated in 0.05177 seconds
