Home » Eclipse Projects » GEF » StickyNoteFigure (Comment Box) in the logic example
StickyNoteFigure (Comment Box) in the logic example [message #187767] Fri, 15 July 2005 09:22 Go to next message
Originally posted by: harsh.ti.com
All,
I am in need of writing a Comment Box in my editor for storing textual
information about the editor. I saw the Logic diagram uses something
similar to what I need. My question is do we need to split up the figure
information from the actual model object? Because in this case, the model
object is fairly simply and is just storing text so why do we need a
BentCornerFigure which extends figure and then StickyNoteFigure which
extends BentCornerFigure? Can't we combine the functionality within the
model object? I understand the need for the feedback figure so we can
provide visual feedback when the object is being moved around.
Any thoughts?
Thank you,
Harsh
Re: StickyNoteFigure (Comment Box) in the logic example [message #187784 is a reply to message #187767] Fri, 15 July 2005 11:23 Go to previous messageGo to next message
Originally posted by: none.unknown.com
"Harsh Sabikhi" <harsh@ti.com> wrote in message
news:4e87adfa299c6d0fd7adfd7f9eee9c3b$1@www.eclipse.org...
> All,
Combine what functionality in the model? I'm not sure what you're getting
at.
> Any thoughts?
> Thank you,
> Harsh
Re: StickyNoteFigure (Comment Box) in the logic example [message #187799 is a reply to message #187784] Fri, 15 July 2005 11:30 Go to previous messageGo to next message
Combining the GUI functionality and the data within the model object.
Harsh
Re: StickyNoteFigure (Comment Box) in the logic example [message #187938 is a reply to message #187799] Mon, 18 July 2005 01:41 Go to previous message
> Harsh
This still doesn't make sense.
The model object has (static/non-visual) attributes/data.
The edit part provides (dynamic/visual) GUI functionality.
The model object may be shared with other applications so cannot possibly
have GUI functionality.
If by GUI functionality you mean graphical attributes then that is data
but annotation data, that should not polute the model. You will find that
the EDiagram example handles this by leaving an Ecore model unpoluted and
adding an extra graphical model.
Your original question suggested merging ...Figures. The examples are
examples. You can of course refactor to taste.
Ed Willink
Previous Topic:SelectionActions & Eclipse Contribution Context Menu
Next Topic:org.eclipse.ui.popupMenus + GEF
Current Time: Thu Mar 13 15:20:13 EDT 2025
Powered by FUDForum. Page generated in 0.04925 seconds
