Home » Language IDEs » ServerTools (WTP) » Adding JBoss runtime configuration from plugin
Adding JBoss runtime configuration from plugin [message #187603] Tue, 06 February 2007 10:44 Go to next message
How can I can add JBoss runtime configuration from plugin.
Code below creates Runtime configuration, but it does not set add JBoss
root location. As I understand that I should send property
"serverRootDirectory" to configuration bu I didn't way how.
I will very appreciate for any help
Mark
IServerType serverTypeJBoss4 = ServerCore
findServerType("org.eclipse.jst.server.generic.jboss4");
if (serverTypeJBoss4 != null)
IRuntimeType runtimeType = serverTypeJBoss4.getRuntimeType();
if (runtimeType != null)
IRuntimeWorkingCopy runtimeWorkingCopy = runtimeType.createRuntime(
"jboss.runtime", monitor);
runtimeWorkingCopy.setLocation(newPath(jbossHomeDir.getCanon icalPath()));
runtimeWorkingCopy.save(true, monitor);
Re: Adding JBoss runtime configuration from plugin [message #187644 is a reply to message #187603] Wed, 07 February 2007 01:04 Go to previous messageGo to next message
Below is a code snippet from the junit tests for jonas. It show the way
to add attributes to a generic server. Of course jboss has a different
set of properties.
GenericServerRuntime runtimeDelegate =
(GenericServerRuntime)runtimeWorkingCopy.loadAdapter(Generic ServerRuntime.class,new
NullProgressMonitor());
HashMap props = new HashMap();
props.put("mappernames", "");
props.put("classPathVariableName", "JONAS");
props.put("serverAddress", "127.0.0.1");
props.put("jonasBase", "C:\\JOnAS-4.1.4");
props.put("jonasRoot", "C:\\JOnAS-4.1.4");
props.put("classPath", "C:\\JOnAS-4.1.4");
props.put("protocols", "C:\\JOnAS-4.1.4");
props.put("port", "9000");
runtimeDelegate.setServerInstanceProperties(props);
//Save the runtime working copy
runtimeWorkingCopy.save(false,null);
Gorkem
> Mark
Re: Adding JBoss runtime configuration from plugin [message #187650 is a reply to message #187644] Wed, 07 February 2007 01:26 Go to previous messageGo to next message
You right, but GenericServerRuntime class is under *.internal package
Mark
Re: Adding JBoss runtime configuration from plugin [message #187843 is a reply to message #187650] Thu, 08 February 2007 16:53 Go to previous messageGo to next message
You can make an API request through bugzilla for it. If the needs are
general enough I'd be happy to provide that.
Gorkem
> Mark
Re: Adding JBoss runtime configuration from plugin [message #187879 is a reply to message #187843] Fri, 09 February 2007 14:53 Go to previous message
Thanks for your answer, I will open request in bugzilla.
Mark
Previous Topic:Generating ant task for warring
Next Topic:Calling export war action in headless mode
Current Time: Fri Nov 07 17:22:01 EST 2025
Powered by FUDForum. Page generated in 0.05183 seconds
