Home » Language IDEs » C / C++ IDE (CDT) » Scanner discovery in Standard make works only one level
Scanner discovery in Standard make works only one level [message #187447] Mon, 12 March 2007 14:26
Originally posted by: deliciap.cradle.com
The ScannerConfig Discovery in Managed make works very well.
However, in Standard Make, it works upto just one level. For e.g.
In a C source, I have #include <stdio.h> so this is visible in the 'Outline
View'
I double click on this file in the outline view & it opens.
Now, stdio.h in turn includes a list of standard headers. However if I try
to open these from the outline view, it can't locate them.
The virtual Includes contains correct entries.
Is there something I've missed out for Standard make?
Thanks!
Delicia.
My plugin.xml contains (The UI plugin uses these):
<extension
id="CraStandardMakePerProjectProfile"
name="%CradlePerProjectProfile.name"
point=" org.eclipse.cdt.make.core.ScannerConfigurationDiscoveryProfi le ">
<scannerInfoCollector
class=" org.eclipse.cdt.make.internal.core.scannerconfig2.PerProject SICollector "
scope="project"/>
<buildOutputProvider>
<open/>
<scannerInfoConsoleParser
class=" org.eclipse.cdt.make.internal.core.scannerconfig.gnu.GCCScan nerInfoConsoleParser "/>
</buildOutputProvider>
<scannerInfoProvider providerId="specsFile">
<run
command="mygcc"
arguments="-E -P -v -dD
${plugin_state_location}/${specs_file}"
class=" org.eclipse.cdt.make.internal.core.scannerconfig2.GCCSpecsRu nSIProvider "/>
class="org.eclipse.cdt.MySpecsConsoleParser"/>
</scannerInfoProvider>
</extension>
<extension
id="CraStandardMakePerFileProfile"
name="%CradlePerFileProfile.name"
class=" org.eclipse.cdt.make.internal.core.scannerconfig2.PerFileSIC ollector "
scope="file"/>
<open/>
class=" org.eclipse.cdt.make.internal.core.scannerconfig.gnu.GCCPerF ileBOPConsoleParser "/>
<scannerInfoProvider providerId="makefileGenerator">
<run
arguments="-f ${project_name}_scd.mk"
command="make"
class=" org.eclipse.cdt.make.internal.core.scannerconfig2.SCDMakefil eGenerator "/>
class=" org.eclipse.cdt.make.internal.core.scannerconfig.gnu.GCCPerF ileSIPConsoleParser "/>
</extension>
Previous Topic:Will CTD4.0 allow building/debugging across Java <--> JNI <--> COM?
Next Topic:Storing the coloring config into a file (profile perhaps)?
Current Time: Sat Sep 13 21:12:16 EDT 2025
Powered by FUDForum. Page generated in 0.02594 seconds
