Home » Language IDEs » C / C++ IDE (CDT) » running gdb as root without running eclipse as root
running gdb as root without running eclipse as root [message #187264] Wed, 07 March 2007 05:35 Go to next message
Originally posted by: lambert_anne.club.lemonde.fr
I am developing a small program that uses the libpcap library. For the
program to work I need to start it as root. By using setuid I managed to
have the program working when using the Run perspective but how do I get
the same with the debugger??
I tried adding an alias: gdb sudo gdb but when started with eclipse I am
still the owner of the process... If I try to start gdb outside of
Eclipse, no problem, owner is root.
Any idea?
Thanks for any help
Anne
Re: running gdb as root without running eclipse as root [message #187293 is a reply to message #187264] Thu, 08 March 2007 06:05 Go to previous messageGo to next message
Hi Anne,
you could try to wrap
sudo gdb $*
into a script and then specify the script as debugger instead of the "gdb"
default.
HTH
Norbert
Re: running gdb as root without running eclipse as root [message #187310 is a reply to message #187293] Thu, 08 March 2007 08:02 Go to previous messageGo to next message
Unfortunately it does not work. Thanks for the help!
I get:
Exec Error: Cannot run ... gdb_root.sh
with gdb_root.sh =
#!/bin/bash
sudo gdb $*
Anyone as another idea?
Anne
Re: running gdb as root without running eclipse as root [message #187332 is a reply to message #187310] Thu, 08 March 2007 14:07 Go to previous messageGo to next message
Originally posted by: brons_eclipsepost.rinspin.com
> I get:
> with gdb_root.sh =
> #!/bin/bash
> sudo gdb $*
Silly question... did you set executable permission on the script?
Re: running gdb as root without running eclipse as root [message #187340 is a reply to message #187310] Thu, 08 March 2007 14:08 Go to previous messageGo to next message
> I get:
> with gdb_root.sh =
> #!/bin/bash
> sudo gdb $*
Silly question... did you set executable permisson on the script?
Re: running gdb as root without running eclipse as root [message #187369 is a reply to message #187340] Fri, 09 March 2007 02:45 Go to previous messageGo to next message
Not a silly question at all... I tried so many different things in the
last few days, that I did not check that!
So yes with executable permission it does work!!
Thanks a lot for your help!
Anne
Re: running gdb as root without running eclipse as root [message #192790 is a reply to message #187369] Thu, 07 June 2007 03:07 Go to previous messageGo to next message
> last few days, that I did not check that! So yes with executable
> Anne
I need help on this issue as well.
I get "Error creating session
sudo: sorry, you must have a tty to run sudo"
Is there a way I can work this around?
Ceylan
Re: running gdb as root without running eclipse as root [message #192881 is a reply to message #192790] Fri, 08 June 2007 04:16 Go to previous messageGo to next message
> > Anne
> Ceylan
You might need one of the graphical versions of sudo. If you are using
kde try using kdesu , and if you are using gnome try gksu instead of the
sudo command.
Joe
Re: running gdb as root without running eclipse as root [message #193059 is a reply to message #192881] Tue, 12 June 2007 02:48 Go to previous messageGo to next message
>> Ceylan
> sudo command.
> Joe
Hello Joe,
Thanks for tip.
Now I understand what the problem is. Although I am using fedora/GNOME
and fedora does not seem to have gksu.
I will further investigate in the fedora forums.
Hasan Ceylan
Re: running gdb as root without running eclipse as root [message #193067 is a reply to message #192881] Tue, 12 June 2007 03:52 Go to previous messageGo to next message
>>> Anne
>> Ceylan
> sudo command.
> Joe
Here's another solution.
(I think) eclipse must be running as root as well to manipulate gdb
login as root
create a file called /etc/security/console.apps/eclipsesu
enter the information below
USER=root
PROGRAM=/usr/bin/eclipse
SESSION=true
create a file called /etc/pam.d/eclipsesu
enter the following informa below
#%PAM-1.0
auth include config-util
account include config-util
session include config-util
do
#ln -s /usr/bin/eclipse /usr/bin/eclipsesu
from gnome or kde run /usr/bin/eclipsesu
This will popup the root passwd screen. Then you are good to go.
Hasan Ceylan
Re: running gdb as root without running eclipse as root [message #1011871 is a reply to message #193067] Wed, 20 February 2013 06:59 Go to previous message
Hi;
I'm having the same problem and tried the above solutions,
(setting debugger to sudo gdb, or to batch file running as gdb as root user)
but I keep getting an error message in Eclipse "Cannot run program" "unknown reason",
when trying to debug.
Please advise me what I'm doing wrong.
Previous Topic:Indexer with multiple projects
Next Topic:Eclipse-CDT and Makefiles
Current Time: Tue Apr 29 01:47:34 EDT 2025
Powered by FUDForum. Page generated in 0.11905 seconds
