Home » Archived » BIRT » launch configuration
launch configuration [message #187186] Fri, 25 August 2006 12:26 Go to next message
I have created a .launch file as per Jasons suggestion and want to know
how birt knows about its existance. Searched everywhere. Do I add some
command in the code creating the report engine. Does Birt just look for
a .launch file?
Re: launch configuration [message #187294 is a reply to message #187186] Fri, 25 August 2006 16:54 Go to previous message
James,
I created a launch configuration when running the Viewer or the RE API in
plug-in format and debugging the application.
look on the Common tab of the launcher.
Jason
There is is a
"James Leotta" <jleotta@bascom.com> wrote in message
news:ecn896$6cj$1@utils.eclipse.org...
>I have created a .launch file as per Jasons suggestion and want to know how
>birt knows about its existance. Searched everywhere. Do I add some command
>in the code creating the report engine. Does Birt just look for a .launch
>file?
> Thanks
Previous Topic:Report gives NULL Pointer Exception on selection of TOC and Export CSV option due to inactivity.
Next Topic:SwingChartViewerSelector Problem
Current Time: Fri Apr 25 19:37:08 EDT 2025
Powered by FUDForum. Page generated in 0.07586 seconds
