Home » Archived » BIRT » Eclipse Chart Engine, PNG, and ImageMap
Eclipse Chart Engine, PNG, and ImageMap [message #186425] |
Mon, 21 August 2006 13:02  |
Originally posted by: molson.airinc.com
Hi, I am having a problem creating an imagemap for a chart I have
created. I am able to create a PNG image just fine and have it display
in a browser, however the imagemap I get is always null.
When I create my chart, I add triggers to my bar series like so:
bsY11.getTriggers( ).add(
TriggerImpl.create(
TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create(
ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create( 500, "my label" )
I then have a servlet to create the png image. That works fine, but my
image map is being returned as null.
here is the interesting part of my get ( cm is the chart ):
IDeviceRenderer idr = null;
final PluginSettings ps = PluginSettings.instance( );
try
idr = ps.getDevice( "dv.PNG" );
catch ( ChartException ex )
ex.printStackTrace( );
// Create a buffered image
BufferedImage image = new BufferedImage( width,
height,
BufferedImage.TYPE_INT_ARGB );
// Draw the chart in the buffered image
Graphics2D g2d = (Graphics2D) image.getGraphics( );
idr.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, g2d );
Bounds bo = BoundsImpl.create( 0, 0, width, height );
bo.scale( 72d / idr.getDisplayServer( ).getDpiResolution( ) );
Generator gr = Generator.instance( );
try
idr.setProperty( IDeviceRenderer.CACHED_IMAGE, image );
gr.render( idr, gr.build( idr.getDisplayServer( ),
cm,
bo,
null,
null,
null ) );
g2d.dispose( );
IImageMapEmitter test = (IImageMapEmitter)idr;
String vals = test.getImageMap();
vals is null, despite the fact that I know there are triggers set up for
the bar series in the chart. Any idea why?
Cheer,
Mike
Re: Eclipse Chart Engine, PNG, and ImageMap [message #186433 is a reply to message #186425] |
Mon, 21 August 2006 13:20   |
> TriggerImpl.create(
> ActionImpl.create(
> try
> height,
> try
> cm,
> bo,
> null,
> null,
> null ) );
> g2d.dispose( );
> Cheer,
> Mike
Re: Eclipse Chart Engine, PNG, and ImageMap [message #186516 is a reply to message #186425] |
Tue, 22 August 2006 04:25   |
try add this before you call gr.render(),
idr.setProperty( IDeviceRenderer.UPDATE_NOTIFIER,
new EmptyUpdateNotifier( cm, gcs.getChartModel( ) ) );
gcs is the return value of gr.build().
> TriggerImpl.create(
> ActionImpl.create(
> try
> height,
> try
> cm,
> bo,
> null,
> null,
> null ) );
> g2d.dispose( );
> Cheer,
> Mike
Re: Eclipse Chart Engine, PNG, and ImageMap [message #186796 is a reply to message #186516] |
Thu, 24 August 2006 10:55  |
This works great foir ONMOUSEOVER_LITERAL triggers, however, when I use
ONMOUSEDOWN_LITERAL, my imagemap is an empty string. Shouldn't imagemap
support mousedown?
Here is my trigger code
TriggerImpl.create(
TriggerCondition.ONMOUSEDOWN_LITERAL,
ActionImpl.create(
ActionType.URL_REDIRECT_LITERAL,
URLValueImpl.create( "http://www.actuate.com", null, null, null, null )
Any ideas?
>> display in a browser, however the imagemap I get is always null.
>> TriggerImpl.create(
>> ActionImpl.create(
>> my image map is being returned as null.
>> try
>> height,
>> try
>> cm,
>> bo,
>> null,
>> null,
>> null ) );
>> g2d.dispose( );
>> for the bar series in the chart. Any idea why?
>> Cheer,
>> Mike
Current Time: Fri Oct 17 02:57:38 EDT 2025
Powered by FUDForum. Page generated in 0.07436 seconds
