Home » Language IDEs » C / C++ IDE (CDT) » Why 64bit Eclipse version
Why 64bit Eclipse version [message #186023] Mon, 26 February 2007 08:32 Go to next message
Originally posted by: fwein.lse.eei.uni-erlangen.de
I hope, I'm not too off-topic:
Why is there a eclipse download for a 64bit jre?
Is the codebase different?
Is an optimized compiler-switch used?
This messes up with my compile once, run anywhere picture and I'm just
curious.
Fabian
Re: Why 64bit Eclipse version [message #186079 is a reply to message #186023] Mon, 26 February 2007 12:32 Go to previous messageGo to next message
Originally posted by: dschaefer.qnx.com
Fabian Wein wrote:
> curious.
> Fabian
Interesting question. The reason for the different downloads is that
Eclipse has a number of native libraries, starting with SWT. The CDT has
a native library for process management and Windows registry access as well.
Now Eclipse is 99% Java so we do get a lot of the benefits of compile
once, run anywhere, but that 1% is probably what makes Eclipse such a
high quality environment. I lived through the pain of IDEs written in
Swing. Eclipse performs like most desktop apps because SWT is mainly C code.
Just my opinion, though.
Doug
Re: Why 64bit Eclipse version [message #186143 is a reply to message #186079] Tue, 27 February 2007 03:57 Go to previous message
> code.
Thanks for the answer! I guess this is also the reason for the versions
of Together. I found writing webapps in JSP much more convenient than in
Swing - but writing AWT applets in the old times when the IE had an old
JRE was really a pain in the back.
Fabian
Previous Topic:"Broken Pipe" error when compiling on Fedora Core
Next Topic:Filtering files with extentions
Current Time: Tue Oct 28 05:04:29 EDT 2025
Powered by FUDForum. Page generated in 0.04818 seconds
