java.lang.OutOfMemoryError: Java heap space [message #185949] |
Fri, 23 February 2007 21:35 |
Originally posted by: g-michalak.ti.com
When I try to open any c source file I get the following error. If I try to
reopen the file it opens fine. When I try to syncronize with CVS eclipse
closes down. This just started happening yesterday, I've been using eclipse
for months and never had this issue. Anybody have any idea what is wrong?
!ENTRY org.eclipse.ui 4 0 2007-02-23 15:25:58.425
!MESSAGE Unable to create editor ID org.eclipse.cdt.ui.editor.CEditor:
Editor could not be initialized.
!STACK 0
Greg
Re: java.lang.OutOfMemoryError: Java heap space [message #185958 is a reply to message #185949] |
Fri, 23 February 2007 21:42 |
> !STACK 0
> Greg
You didn't say which release you were using. If you are using the Sun
JVM, you might want to try the -Xmx512M to increase the heap size.
Doug
FUDForum. Page generated in 0.02958 seconds
