Re: Pagination... How? [message #183311 is a reply to message #183255] |
Tue, 08 August 2006 09:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: raison.fermat.eu
Is the data on one single page or paginated on several pages ?
If it's on one page, it's the client's browser which can have problems.
The only solution is to add page breaks to limit the size of each page to avoid browser error.
If the Out of Memory appears in a dialog box which looks like the parameter box, it's your application server which didn't have enough memory.
In that case re-configure your application server.
For tomcat, at launchtime add to java expression -Xms128m -Xmx512m something like that.
Good luck.
Sachin Dharmapurikar wrote:
> Hello Everybody,
> Finally I could manage to display paginated report. I wasn't knowing to
> assign the Master page to source items.
> Now another problem is there-
> 1. When I try to run a query on 1.1 GB of data in table... it simply
> died by giving exception "Out of Memory".
> 2. Then I tried to fetch 10000 rows by using "LIMIT" clause in sQL and
> now the report is showing up. It is taking very long time to display
> this report. Already few people reported this bug in last two days...
> any workaround solution for this?
> -Sachin
>> Hello everybody,
>> I donloaded Birt-2.1.0 all-in-one designer build. I saw some cool
>> demos online and thought to give a try. I have setup the runtime and
>> everything else on my machine. My database table has 1.1 GB of data. I
>> just fetch partial data and try to display on the report.
>> I am using "WebViewerExample"... when I view -
>> http://localhost:8080/WebViewerExample/frameset?__report=Pag ination.rp
>> tdesign
>> where "Pagination.rptdesign" is my report name, it displays as single
>> page. I am expecting it should paginate the report. After trying a lot
>> I couldn't get a paginated report.
>> Is WebViewerExample is same as "Ajax Viewer"?... This is one of
>> critical feature to my product.
>> Any help will be appriciated.
>> Sachin
FUDForum. Page generated in 0.02545 seconds
