Home » Eclipse Projects » Subversive » Mylyn integration not working
Mylyn integration not working [message #17231] Thu, 24 April 2008 12:57 Go to next message
Originally posted by: do.not.eat.yellow.snow.gmail.com
Last year I was using the Mylyn integration, it automatically created change sets and commit messages perfectly. But for some reason it's no longer working for me. Using latest subversive v20080423 and mylyn v20080402 the integration plugin doesn't seem to do anything, does it work ok for everyone else?
I can see the Mylyn integration plugin under "Manage configuration" but not under "About" --> "Plugin details". Any clue as to what the problem might be?
Martin
Re: Mylyn integration not working [message #17771 is a reply to message #17231] Fri, 25 April 2008 10:07 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Helo Martin,
If Mylyn with build id v20080402, which you use, has version 3.0.0 then
the problem relates to incorrectly specified version compatibility
settings (in Subversive integration for Mylyn). This problem is fixed
today and fix will be available to download from the Eclipse mirrors
shortly (it's available now on the main download source).
> Martin
Re: Mylyn integration not working [message #17784 is a reply to message #17771] Fri, 25 April 2008 11:05 Go to previous messageGo to next message
No, it's Mylyn 2.3.2 but nothing seems to happen. I also tried eclipse -clean without success.
If it works for everyone else, I guess I'll just try to reinstall Eclipse and see if that helps.
Martin
On Fri, 25 Apr 2008 16:07:39 +0200, Alexander Gurov <alexander.gurov@polarion.org> wrote:
> Helo Martin,
>> Martin
Re: Mylyn integration not working [message #17791 is a reply to message #17784] Fri, 25 April 2008 11:57 Go to previous message
I just downloaded "Eclipse IDE for Java Developers" from here:
http://www.eclipse.org/downloads/
and immediately installed Subversive + Mylyn integration, but it still doesn't seem to do anything...? No automatic change sets, etc.
Martin
On Fri, 25 Apr 2008 17:05:34 +0200, Martin Strand <do.not.eat.yellow.snow@gmail.com> wrote:
> Martin
>> Helo Martin,
>>> Martin
Previous Topic:404 for eclipse.org update site
Next Topic:red exclamation mark on folders?
Current Time: Mon Apr 28 02:55:41 EDT 2025
Powered by FUDForum. Page generated in 0.03966 seconds
