Error encountered while trying to create a project [message #182524] |
Tue, 20 January 2004 19:37 |
Originally posted by: salinaja.americasm01.nt.com
--------------E06389F439978FD4A7F3DBD2
Content-Type: text/plain; charset=iso-8859-2
I recently installed Eclipse 2.1 for Solaris and every time I try to
create a project in a ClearCase directory, I get the following error:
An error occured withe creating project
check log for deatils
Reason:
Errors ocurred while refreshing resources with the local file system
When I check the log file for details it reports the following:
!SESSION Jan 19, 2004 14:33:07.338
java.version=1.4.2_01
BootLoader constants: OS=solaris, ARCH=sparc, WS=motif, NL=en
Command-line arguments: -os solaris -ws motif -arch sparc -install
file:/localspace/eclipse/
!ENTRY org.eclipse.core.resources 1 1 Jan 19, 2004 14:33:07.349
!MESSAGE Could not load library: libcore_2_1_0a.so. This library
provides platform-specific optimizations for certain file system
operations. This library is not present on all platforms, so this may
not
be an error. The resources plug-in will safely fall back to using
java.io.File functionality.
!ENTRY org.eclipse.jdt.ui 4 10001 Jan 19, 2004 14:33:31.98
!MESSAGE Internal Error
!STACK 1
org.eclipse.core.internal.resources.ResourceException: Errors occurred
while refreshing resources with the local file system.
org.eclipse.core.internal.localstore.FileSystemResourceManag er.refreshResource(FileSystemResourceManager.java:516)
org.eclipse.core.internal.localstore.FileSystemResourceManag er.refresh(FileSystemResourceManager.java:499)
org.eclipse.core.internal.resources.Resource.refreshLocal(Re source.java:1151)
at org.eclipse.core.internal.resources.Project.open(Project.jav a:698)
org.eclipse.jdt.internal.ui.wizards.buildpaths.BuildPathsBlo ck.createProject(BuildPathsBlock.java:560)
org.eclipse.jdt.ui.wizards.JavaCapabilityConfigurationPage.c reateProject(JavaCapabilityConfigurationPage.java:182)
org.eclipse.jdt.internal.ui.wizards.NewProjectCreationWizard Page.updateProject(NewProjectCreationWizardPage.java:115)
org.eclipse.jdt.internal.ui.wizards.NewProjectCreationWizard Page$1.run(NewProjectCreationWizardPage.java:86)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:302)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:252)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 758)
org.eclipse.jdt.internal.ui.wizards.NewProjectCreationWizard Page.changeToNewProject(NewProjectCreationWizardPage.java:94 )
org.eclipse.jdt.internal.ui.wizards.NewProjectCreationWizard Page.setVisible(NewProjectCreationWizardPage.java:64)
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:959)
org.eclipse.jface.wizard.WizardDialog.access$1(WizardDialog. java:940)
at org.eclipse.jface.wizard.WizardDialog$3.run(WizardDialog.jav a:929)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:927)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:684)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:316)
at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:423)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:810)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2148)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1914)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:583 )
at org.eclipse.jface.window.Window.open(Window.java:563)
org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:107)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:456)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:403)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionItem.java:397)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java:72)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!ENTRY org.eclipse.core.resources 4 271 Jan 19, 2004 14:33:31.114
!MESSAGE Errors occurred while refreshing resources with the local file
system.
!SUBENTRY 1 org.eclipse.core.resources 4 278 Jan 19, 2004 14:33:31.115
!MESSAGE
is an invalid resource name.
Does anyone know how I might be able to get around this??
Thank you.
Salinah J.
Content-Type: text/html; charset=iso-8859-2
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
<font color="#3333FF">Hello,</font><font color="#3333FF"></font>
<p><font color="#3333FF">I recently installed Eclipse 2.1 for Solaris and
every time I try to create a project in a ClearCase directory, I get
the following error:</font><font color="#3333FF"></font>
<p>An error occured withe creating project
<br>check log for deatils
<p>Reason:
<br>Errors ocurred while refreshing resources with the local file system
<p><font color="#3333FF">When I check the log file for details it reports
the following:</font>
<p>!SESSION Jan 19, 2004 14:33:07.338 ---------------------------------------------
<br>java.version=1.4.2_01
<br>java.vendor=Sun Microsystems Inc.
<br>BootLoader constants: OS=solaris, ARCH=sparc, WS=motif, NL=en
<br>Command-line arguments: -os solaris -ws motif -arch sparc -install
<A HREF="file:/localspace/eclipse/">file:/localspace/eclipse/ </A>
<br>!ENTRY org.eclipse.core.resources 1 1 Jan 19, 2004 14:33:07.349
<br>!MESSAGE Could not load library: libcore_2_1_0a.so. This library
provides platform-specific optimizations for certain file system operations.
This library is not present on all platforms, so this may not
<br>be an error. The resources plug-in will safely fall back to using
<br>!ENTRY org.eclipse.jdt.ui 4 10001 Jan 19, 2004 14:33:31.98
<br>!MESSAGE Internal Error
<br>!STACK 1
<br>org.eclipse.core.internal.resources.ResourceException: Errors occurred
<br> at org.eclipse.core.internal.localstore.FileSystemResourceManag er.refreshResource(FileSystemResourceManager.java:516)
<br> at org.eclipse.core.internal.localstore.FileSystemResourceManag er.refresh(FileSystemResourceManager.java:499)
<br> at org.eclipse.core.internal.resources.Resource.refreshLocal(Re source.java:1151)
<br> at org.eclipse.core.internal.resources.Project.open(Project.jav a:698)
<br> at org.eclipse.jdt.internal.ui.wizards.buildpaths.BuildPathsBlo ck.createProject(BuildPathsBlock.java:560)
<br> at org.eclipse.jdt.ui.wizards.JavaCapabilityConfigurationPage.c reateProject(JavaCapabilityConfigurationPage.java:182)
<br> at org.eclipse.jdt.internal.ui.wizards.NewProjectCreationWizard Page.updateProject(NewProjectCreationWizardPage.java:115)
<br> at org.eclipse.jdt.internal.ui.wizards.NewProjectCreationWizard Page$1.run(NewProjectCreationWizardPage.java:86)
<br> at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:302)
<br> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:252)
<br> at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 758)
<br> at org.eclipse.jdt.internal.ui.wizards.NewProjectCreationWizard Page.changeToNewProject(NewProjectCreationWizardPage.java:94 )
<br> at org.eclipse.jdt.internal.ui.wizards.NewProjectCreationWizard Page.setVisible(NewProjectCreationWizardPage.java:64)
<br> at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:959)
<br> at org.eclipse.jface.wizard.WizardDialog.access$1(WizardDialog. java:940)
<br> at org.eclipse.jface.wizard.WizardDialog$3.run(WizardDialog.jav a:929)
<br> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
<br> at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:927)
<br> at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:684)
<br> at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:316)
<br> at org.eclipse.jface.dialogs.Dialog$1.widgetSelected(Dialog.jav a:423)
<br> at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
<br> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
<br> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:810)
<br> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2148)
<br> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1914)
<br> at org.eclipse.jface.window.Window.runEventLoop(Window.java:583 )
<br> at org.eclipse.jface.window.Window.open(Window.java:563)
<br> at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:107)
<br> at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
<br> at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:456)
<br> at org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:403)
<br> at org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionItem.java:397)
<br> at org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java:72)
<br> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
<br> at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
<br> at org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
<br> at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
<br> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
<br> at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
<br> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
<br> at java.lang.reflect.Method.invoke(Method.java:324)
<br> at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
<br> at org.eclipse.core.launcher.Main.run(Main.java:747)
<br> at org.eclipse.core.launcher.Main.main(Main.java:583)
<br>!ENTRY org.eclipse.core.resources 4 271 Jan 19, 2004 14:33:31.114
<br>!MESSAGE Errors occurred while refreshing resources with the local
file system.
<br>!SUBENTRY 1 org.eclipse.core.resources 4 278 Jan 19, 2004 14:33:31.115
<br>!MESSAGE
<br> is an invalid resource name.
<br> <font color="#3333FF"></font>
<p><font color="#3333FF">Does anyone know how I might be able to get around
this??</font><font color="#3333FF"></font>
<p><font color="#3333FF">Thank you.</font><font color="#3333FF"></font>
<p><font color="#3333FF">Salinah J.</font>
<br>
<br> </html>
--------------E06389F439978FD4A7F3DBD2--
FUDForum. Page generated in 0.03904 seconds
