automatically call make when debug/run [message #181784] |
Thu, 04 January 2007 07:52 |
Originally posted by: mliu.nextwave.com
I have a standard make C++ project. Every time I run/debug the
application, Eclipse automatically calls make to rebuild. Are there
anyway to disable that?
Thanks!
Mike
Re: automatically call make when debug/run [message #181844 is a reply to message #181787] |
Fri, 05 January 2007 18:57 |
Thanks, but it doesn't work.
The "Build automatically" option only affects whether the project is
rebuilt or not once there is a source change.
My problem is that when running or debugging, the make is called first
even though there is no source change. Certainly make does not
re-compile everything, but I wonder why the make must be called before
running/debugging, or my setting is incorrect.
Thanks!
Geert Vancompernolle wrote:
> Mike wrote:
>> Thanks!
>> Mike
> "Projects" -> "Build Automatically": make sure there's no checkbox in
> front of this item.
> If so, click on that item and the checkbox should disappear...
> Best rgds,
> --Geert
Re: automatically call make when debug/run [message #181909 is a reply to message #181844] |
Sun, 07 January 2007 23:04 |
Originally posted by: porges.comcast.net
"Mike" <mliu@nextwave.com> wrote in message
news:enm6vs$243$1@utils.eclipse.org...
> even though there is no source change. Certainly make does not re-compile
That's common IDE behaviour in general -- both MSVC and CodeWarrior do it;
*especially* if you have Build Automatically off, it protects you against
debugging
an executable against source that has been updated but not built.
Re: automatically call make when debug/run [message #182070 is a reply to message #181917] |
Wed, 10 January 2007 18:08 |
Axel Mueller wrote:
> Have a look at Preferences->Run/Debug. Disable "Build before launching"
> in General Options.
>>> first even though there is no source change. Certainly make does not
>>> before running/debugging, or my setting is incorrect.
Thank you, that works!
FUDForum. Page generated in 0.03503 seconds
