Home » Language IDEs » Java Development Tools (JDT) » protecting regions of java code from editing
protecting regions of java code from editing [message #181341] Thu, 07 October 2004 05:08 Go to next message
Originally posted by: edoardoATenigmatecDOTnet.no.spam
how could I prevent some "parts" of a java source from being
edited/changed while leaving the rest of the file normally editable ??
TIA,
Edo
PS - I had defining a custom annotation and a custom marker,
and then lattaching listsners to the sourceviewer to set doit=false to
verify events.
this only stops some typing in the java editor, while other actions (eg
text move/up and down) are still doable and "screw" the source.
So I am looking at some "veto" coming frm the Document or ... the Java
Model/Java DOM/AST ?
Re: protecting regions of java code from editing [message #181352 is a reply to message #181341] Thu, 07 October 2004 05:41 Go to previous messageGo to next message
See the thread at
news://news.eclipse.org:119/cj1ici$cng$1@eclipse.org
-tom
Edoardo Comar wrote:
> Hi
> TIA,
> Edo
> verify events.
Re: protecting regions of java code from editing [message #181365 is a reply to message #181352] Thu, 07 October 2004 06:13 Go to previous messageGo to next message
Tom,
(don't know how to get to that thread using the hyperlink you posted,
anyway)
that was a thread I started some time ago and I thank you for your answer.
The problem I have is that there are lots of "actions" (*)
that do not fire VerifyEvent event and so I can't block them.
I must also worry about refactorings - as my source would be changed
even if there is no editor open on it!!
this is why I am tring to block these changes at a different level.
any ideas (from anyone in the community) ?
Edo
(*)e.g. cut (this may be a bug I submitted in bugzilla),
move selected lines up/down etc
refactorings!
Tom Eicher wrote:
> See the thread at
> -tom
>> Hi
>> TIA,
>> Edo
>> verify events.
>> (eg text move/up and down) are still doable and "screw" the source.
Re: protecting regions of java code from editing [message #181383 is a reply to message #181365] Thu, 07 October 2004 08:46 Go to previous message
That is why I suggested blocking the events from inside a custom
document, which is the model behind what you see in the editor and
receives all changes, including refactorings and others that operate
directly on the document.
The problem with this is that there is no veto-mechanism similar to the
one offered by VerifyEvent - I am afraid there is currently no easy
solution for this.
-tom
Previous Topic:Extending content-assist
Next Topic:How do you tell if a CompilationUnit is in error?
Current Time: Tue Jul 01 11:06:42 EDT 2025
Powered by FUDForum. Page generated in 0.49668 seconds
