Home » Archived » Test and Performance Tools Platform (TPTP) » Having trouble getting TPTP 3.3 to work with Eclipse 3.0
Having trouble getting TPTP 3.3 to work with Eclipse 3.0 [message #17047] Tue, 26 April 2005 18:27 Go to next message
Originally posted by: jeffrey.kesselman.sun.com
Hi Guys,
im SURE this is a stupid question and I;m sorry, but I thought I
carefully follwoed the isntructions on the website. I downloaded
the three hyades Zips into m yeclispe directory (runtime, test and
exampels) and verified that they put .so files in the plugins
directory. I downlaoded the rac, unzipepd it to ist own dir, and got it
running.
Then i restarted eclipse.
The problem is I see no eidence of the plug-in in eclispe. i have no
profiling perspective nor do I seme to have a button or menu item to
start the profiler.
What should I be checking?
JK
Re: Having trouble getting TPTP 3.3 to work with Eclipse 3.0 [message #17077 is a reply to message #17047] Tue, 26 April 2005 19:36 Go to previous messageGo to next message
Additional information. I checked the plug-ins using the About menu. I
see all sorts of Hyades plugins in the list.
But I have no Profilig and Logging perspective that I can find :(
Help? Please?
Re: Having trouble getting TPTP 3.3 to work with Eclipse 3.0 [message #17278 is a reply to message #17077] Mon, 02 May 2005 08:51 Go to previous messageGo to next message
Hi Jeff,
Only thing I can think of is to try and delete everything in your
eclipse/configuration directory, except for the config.ini file. This might
result in the plugins loading correctly.
George
"Jeff Kesselman" <jeffrey.kesselman@sun.com> wrote in message
news:d4mjgu$5u4$1@news.eclipse.org...
> Help? Please?
Re: Having trouble getting TPTP 3.3 to work with Eclipse 3.0 [message #17305 is a reply to message #17278] Mon, 02 May 2005 12:54 Go to previous message
You also need to download and unzip into your Eclipse directory the EMF
2.0.2 and XSD 2.0.2 packages. This will do the trick.
"George Christelis" <george.christelis@scapatech.com> wrote in message
news:d5583c$jtp$1@news.eclipse.org...
> Hi Jeff,
might
> George
> > Help? Please?
Previous Topic:Is it possible to use the TPTP framework to test J2EE based applications
Next Topic:Can' open ExecutionStatistic view 3.2A
Current Time: Thu Mar 13 13:53:58 EDT 2025
Powered by FUDForum. Page generated in 0.23453 seconds
