Home » Language IDEs » ServerTools (WTP) » Added value of Web Module
Added value of Web Module [message #179994] Tue, 26 September 2006 14:44 Go to next message
Originally posted by: tomh.a-t-g.com
We have just moved to WTP 1.0.3 and we like it so far. We are currently
managing Tomcat(5.0.30) through WTP. We have our Tomcat deploying our
application by sticking a file in TOMCAT_HOME/conf/Catalina/localhost
pointing back to our workspace. We currently have no Web Modules setup. I
was wondering what added value would that bring if we did? As a note we do
have "Run modules directly from the workspace" unchecked so it will start
our application and all in Tomcat. So maybe that would be a benefit to run
as a Web Module and just run our app, correct?
Thanks in advance,
Tom
Re: Added value of Web Module [message #180002 is a reply to message #179994] Tue, 26 September 2006 16:06 Go to previous message
For the typical Dynamic Web Project, there is no single folder that
contains a complete image of the Web application. Its content is under
the WebContent folder, but compiled classes for servlets and other
classes appear by default under the project's "build/classes" folder.
Assembly of these folders, and potentially other dependencies, occurs
when the project is published to a server, which happens automatically
after the project is added to the server. This suggests that your file
under the "conf/Catalina/localhost" directory may not be getting
everything. It depends on what is actually in your project.
Larry
> Thanks in advance,
> Tom
Previous Topic:problem when attempting to implement a GenericPublisher
Next Topic:API to add to Snippets view
Current Time: Mon Sep 15 23:13:39 EDT 2025
Powered by FUDForum. Page generated in 0.04213 seconds
