External jars - plugin [message #179679] |
Tue, 28 September 2004 01:08 |
Originally posted by: arthur.deltacore.com.br
I'm making a class-generator plugin, and the classes generated by the
plugin depend on a external jar (DOM4J). I've included it in the build
output (the generated classes are in the org.foo package, and the jar is
at org/foo/lib). However, when the classes are generated, they simply
don´t recognize the dom4j import; I have to manually import the external
jar into the project build path. Is there a way to automatically do this
when the plugin generate the classes?
Arthur Casals
Re: External jars - plugin [message #179846 is a reply to message #179747] |
Tue, 28 September 2004 15:09 |
Markus Keller wrote:
> Arthur Casals wrote:
>> Hello,
>> is at org/foo/lib). However, when the classes are generated, they
>> simply don´t recognize the dom4j import; I have to manually import the
>> external jar into the project build path. Is there a way to
>> automatically do this when the plugin generate the classes?
> Use IJavaProject#getRawClasspath() and #setRawClasspath(..) to modify a
> project's classpath. You can create new classpath entries with
> JavaCore.newLibraryEntry(..).
> HTH
> Markus
Great, problem solved. Thanks a lot.
Arthur Casals
FUDForum. Page generated in 0.04246 seconds
