Views listeners [message #178619] |
Mon, 12 January 2004 17:04 |
Originally posted by: angeles_sorano.yahoo.com.ar
Hello!!
I have the following problems:
1. Depending the execution of an action, I want to show, throws 2 views,
some information from 2 different files . But when I want to show the
second view I have this error (An error has occurred when creating this
view) and the .log is the following:
!SESSION Jan 12, 2004 10:33:35.950
java.version=1.4.0_01
Command-line arguments: -pdelaunch -dev bin -feature org.eclipse.platform
-data C:\eclipse\runtime-workspace -os win32 -ws win32 -arch x86 -nl en_US
-configuration
file:C:/eclipse/workspace/.metadata/.plugins/org.eclipse.pde .core/C__eclipse_runtime-workspace/platform.cfg
-install file:C:/eclipse/
!ENTRY org.eclipse.ui.workbench 4 2 Jan 12, 2004 10:33:35.990
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
com.ibm.liniotest.views.LiniotestOutView.createPartControl(L iniotestOutView.java:116)
at org.eclipse.ui.internal.PartPane$4.run(PartPane.java:141)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:137)
at org.eclipse.ui.internal.ViewPane.createChildControl(ViewPane .java:211)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :186)
at org.eclipse.ui.internal.ViewPane.createControl(ViewPane.java :190)
org.eclipse.ui.internal.PartTabFolder.createPartTab(PartTabF older.java:252)
org.eclipse.ui.internal.PartTabFolder.createControl(PartTabF older.java:224)
org.eclipse.ui.internal.PartSashContainer.createControl(Part SashContainer.java:192)
org.eclipse.ui.internal.PerspectivePresentation.activate(Per spectivePresentation.java:96)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:725)
org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPa ge.java:1799)
org.eclipse.ui.internal.WorkbenchWindow$7.run(WorkbenchWindo w.java:1496)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:1483)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1363)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1263)
at org.eclipse.ui.internal.Workbench.access$10(Workbench.java:1 223)
at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:1141 )
org.eclipse.ui.internal.Workbench.openPreviousWorkbenchState (Workbench.java:1093)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:870)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1373)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
In 166 line, 2nd. view is making reference to the same file again, because
first it is referenced in the 1st. view.
For me It is like the second view can't get the listener of the Resource
Navigator because the first view has it. But I don't know how to fix this
problem.
Thanks for advice.....
Ma. de los Angeles Sorano
mailto:soranom@ar.ibm.com
FUDForum. Page generated in 0.02756 seconds
