JBoss AS [message #178485] |
Mon, 04 September 2006 15:42 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: apacheco.nip.gub.uy
Hi, when I try to create a web service according with the tutorial to
create a botton-up web service I receive this red message in the wizard
when I select my server:
"JBoss AS 4.0 does not support the Apache Axis Web service runtime.
Choose a different server or runtime to proceed through the Web services
wizard."
Can web services be created in JBossAS Server? if the answer is yes, the
Apache Axis runtime is the correct runtime for this or I have to define
another one? which one?
thank you.
Re: JBoss AS [message #178502 is a reply to message #178485] |
Mon, 04 September 2006 20:19 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: news.e-beyond.de
On Mon, 04 Sep 2006 12:42:59 -0300, Aníbal Pacheco
You can't use Axis with JBossAS Server. They use an customized version
of axis within the server. So if you have to use jboss for your
webservices you'll got some other choices:
a) You'll use the jboss stuff
http://labs.jboss.com/portal/jbossws/user-guide/en/html/inde x.html
b) You'll use another "webservice-engine"
(xfire for example, I would suggest use it together with spring)
yours
me
FUDForum. Page generated in 0.07792 seconds
