BundleException [message #178258] |
Mon, 12 January 2004 00:22 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: dcorbin.machturtle.com
I have a plugin I'm trying to package. Under 2.1.x, it seems to work OK.
Under 3.0, I get the exception and stack trace shown below. I'd really
appreciate some pointers on what I've messed up...
David
!ENTRY org.eclipse.core.runtime 4 1 Jan 11, 2004 19:11:08.436
!MESSAGE Plug-in net.sourceforge.tde.jdt.ui was unable to load class
net.sourceforge.tde.jdt.properties.JdtAutoTestPropertyPage.
!STACK 0
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: probably another version has been chosen
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:445)
org.eclipse.osgi.framework.internal.core.Bundle.start(Bundle .java:328)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:133)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:125)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:114)
org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:160)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:157)
org.eclipse.ui.internal.dialogs.RegistryPageContributor.crea tePage(RegistryPageContributor.java:87)
org.eclipse.ui.internal.dialogs.PropertyPageNode.createPage( PropertyPageNode.java:51)
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1061)
org.eclipse.jface.preference.PreferenceDialog$9.selectionCha nged(PreferenceDialog.java:574)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:431)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:813)
at org.eclipse.core.runtime.Platform.run(Platform.java:457)
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:429)
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:680)
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:698)
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:198)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:193)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 334)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:102)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:1822)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1628)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:586 )
at org.eclipse.jface.window.Window.open(Window.java:566)
org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDial ogAction.java:164)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:509)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:461)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:408)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
<snip>
Re: BundleException [message #178293 is a reply to message #178258] |
Mon, 12 January 2004 02:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jeff_mcaffer.ca.ibm.com
David,
First an apology. The diagnostic reporting is not yet up to scratch so the
messages are not particularly helpful. Looking at this one it seems that
the framework is trying to activate/start your plugin and some class could
not be loaded. Try running this under the debugger and catching
ClassNotFoundException right around the time you are executing this code.
Of, use a conditional breakpoint in BundleHost.startWorker() (conditional on
the bundle/plugin being started is yours) and see where it is failing.
Jeff
"David Corbin" <dcorbin@machturtle.com> wrote in message
news:btspag$jt3$1@eclipse.org...
> David
> !STACK 0
> at
ava:445)
> at
> at
> at
> at
> at
> at
> at
:157)
> at
> at
..java:51)
> at
:1061)
> at
ialog.java:574)
> at
> at
:813)
> at
edViewer.java:429)
> at
..java:680)
> at
..java:698)
> at
:198)
> at
> at
4)
> at
> at
tem.java:461)
> at
tionItem.java:408)
> <snip>
Re: BundleException [message #178904 is a reply to message #178756] |
Tue, 13 January 2004 02:17 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Am I to understand that if you launch a runtime workbench everything works
but if you launch from the exe you get the problem you described? This is
quite strange.
You can start Eclipse under the debugger by launching as a Java Application
rahter than a runtime workbench. Just launch your given install (say M6) by
creating a JAva app launch configuraiton and putting the M6 startup.jar on
the classpath. The main class to run is org.eclipse.core.launcher.Main (the
only class in startup.jar). Add whatever command line args you like and
voila! You have to futz around with source a bit but if you have the
relevant source in your workspace the debugger typically finds it even
though it is not the source you are actually running.
If you find that it is actually a problem in eclipse (as opposed to some
configuration issue) please open a bug report for this in the Equinox -
General area. As much detail as possible would be appreciated.
Jeff
"David Corbin" <dcorbin@ieee.org> wrote in message
news:btuvb9$6s4$1@eclipse.org...
> What is the correct way to launch the Eclipse SDK under the debugger, so
> that this is tested under "natural" circumstances? (i.e., using the PDE I
> know things are loaded in a specialized way, and I have no problems with
> that).
> David
> Jeff McAffer wrote:
> > David,
> > the
that
could
code.
(conditional
> > on
> > Jeff
OK.
> >> David
> >> !STACK 0
> >> at
> > ava:445)
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> > :157)
> >> at
> >> at
> > .java:51)
> >> at
> > :1061)
> >> at
> > ialog.java:574)
> >> at
> >> at
> > :813)
> >> at
> > edViewer.java:429)
> >> at
> > .java:680)
> >> at
> > .java:698)
> >> at
> > :198)
> >> at
> >> at
> >> at
> >> at org.eclipse.jface.window.Window.runEventLoop(Window.java:586 ) at
> >> org.eclipse.jface.window.Window.open(Window.java:566) at
> > 4)
> >> at
> >> at
> > tem.java:461)
> >> at
> > tionItem.java:408)
> >> <snip>
Re: BundleException [message #180210 is a reply to message #178904] |
Thu, 15 January 2004 02:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> quite strange.
Yes. That's EXACTLY the problem.
> Application rahter than a runtime workbench. Just launch your given
> install (say M6) by creating a JAva app launch configuraiton and putting
> (the
Thanks.
I will.
> Jeff
>> I know things are loaded in a specialized way, and I have no problems
>> with that).
>> David
>> Jeff McAffer wrote:
>> > David,
>> > the
> that
> could
> code.
> (conditional
>> > on
>> > Jeff
> OK.
>> >> really appreciate some pointers on what I've messed up...
>> >> David
>> >> !STACK 0
>> >> at
>> > ava:445)
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> > :157)
>> >> at
>> >> at
>> > .java:51)
>> >> at
>> > :1061)
>> >> at
>> > ialog.java:574)
>> >> at
>> >> at
>> > :813)
>> >> at
>> > edViewer.java:429)
>> >> at
>> > .java:680)
>> >> at
>> > .java:698)
>> >> at
>> > :198)
>> >> at
>> >> at
> at
>> >> at
>> >> at
>> >> at org.eclipse.jface.window.Window.open(Window.java:566) at
>> > 4)
>> >> at
>> >> at
>> > tem.java:461)
>> >> at
>> > tionItem.java:408)
>> >> at
>> >> <snip>
Re: BundleException [message #180218 is a reply to message #178904] |
Thu, 15 January 2004 02:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
When I attempt to launch Eclipse in this manner, it simply terminates
immediately. I tried to debug it, but I don't have the source to main, as
near as I can tell.
> quite strange.
> (the
> Jeff
>> with that).
>> David
>> Jeff McAffer wrote:
>> > David,
>> > the
> that
> could
> code.
> (conditional
>> > on
>> > Jeff
> OK.
>> >> David
>> >> !STACK 0
>> >> at
>> > ava:445)
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> >> at
>> > :157)
>> >> at
>> >> at
>> > .java:51)
>> >> at
>> > :1061)
>> >> at
>> > ialog.java:574)
>> >> at
>> >> at
>> > :813)
>> >> at
>> > edViewer.java:429)
>> >> at
>> > .java:680)
>> >> at
>> > .java:698)
>> >> at
>> > :198)
>> >> at
>> >> at
> at
>> >> at
>> >> at
>> > 4)
>> >> at
>> >> at
>> > tem.java:461)
>> >> at
>> > tionItem.java:408)
>> >> at
>> >> <snip>
FUDForum. Page generated in 0.04816 seconds
