WSDL 1.1 Binding Extensions for SOAP 1.2 [message #178208] |
Tue, 29 August 2006 21:28 |
Originally posted by: jdoyleoss.gmail.com
I've looked at the 1.5 release info and the 2.0 project plan, and can't
find any mention of the WSDL 1.1 Binding Extensions for SOAP 1.2. Is it in
the plan to support this specification draft?
thanks
jd
Re: WSDL 1.1 Binding Extensions for SOAP 1.2 [message #178290 is a reply to message #178208] |
Wed, 30 August 2006 15:15 |
I think I may have figured out a fix for my problem, but would
appreciate if someone in the know would validate the approach.
The binding extensions I mentioned are declared in a namespace, that
unlike most of the standard schemas, does not correspond to a URL.
Because if this the standard WSDL validation fails. From looking
through the validation code I think the right approach is to implement
my own IExtensibleURIResolver that will recognize this namespace and
provide the correct location.
Is this a good approach?
thanks
> in the plan to support this specification draft?
> thanks
> jd
FUDForum. Page generated in 0.03250 seconds
