Home » Eclipse Projects » Eclipse Platform » content assistant
content assistant [message #176706] |
Wed, 07 January 2004 13:34 |
Originally posted by: pieter.west.NOSPAM.nl
I'm trying to add content assistance to an editor I'm writing. However, in
the Edit-menu the item "Content assist" is not showing up.
For this part of the editor I'm relying on the code from a book "The Java
developer's guide to Eclipse" from Shavor. I essentially copied the code
from that book. It does, however, not seem to work (i.e. Ctrl+Space does
nothing).
The code below is what, to my knowledge, should get content assistance to
work:
public IContentAssistant getContentAssistant(ISourceViewer sourceViewer) {
ContentAssistant assistant;
assistant = new ContentAssistant();
assistant.setContentAssistProcessor(
new MyCompletionProcessor(),
IDocument.DEFAULT_CONTENT_TYPE);
assistant.enableAutoActivation(true);
assistant.setAutoActivationDelay(500);
assistant.setProposalPopupOrientation(
IContentAssistant.CONTEXT_INFO_BELOW);
assistant.setContextInformationPopupOrientation(
assistant.enableAutoInsert(true);
return assistant;
However, I'm probably forgetting something. Could someone point out to me
what I should do to get it to work.
Re: content assistant [message #176729 is a reply to message #176706] |
Wed, 07 January 2004 13:57 |
Originally posted by: jparks.noteworthyms.com
What's going on in MyCompletionProcessor? Specifically, what's inside
computeCompletionProposals?
Do you have a properties file configured for the plugin?
-joe
"Pieter van der Spek" <pieter@west.NOSPAM.nl> wrote in message
news:bth1t9$flo$1@eclipse.org...
> nothing).
> work:
> return assistant;
Re: content assistant [message #176827 is a reply to message #176729] |
Wed, 07 January 2004 17:37 |
Originally posted by: eclipse.guide.removeMe.andMeToo.earthlink.net
There is an errata for this chapter that might be the cause. See errata on
this page:
http://www.awprofessional.com/catalog/product.asp?product_id ={DF615A81-6FB0-
4130-9EA4-E2D0BEF340E3}. I thought the publisher did a fairly good job of
hiding this page <g>. If that's not it, repost and I'll bring it to Scott's
attention.
-- Dan
co-author, "The Java Developer's Guide to Eclipse"
http://www.amazon.com/exec/obidos/ASIN/0321159640
"Joe Parks" <jparks@noteworthyms.com> wrote in message
news:bth36l$h6o$1@eclipse.org...
> -joe
in
Java
> > nothing).
to
> > work:
> > return assistant;
me
Re: content assistant [message #177144 is a reply to message #176729] |
Thu, 08 January 2004 12:43 |
This is what happens in MyCompletionProcessor:
public ICompletionProposal[] computeCompletionProposals(ITextViewer
viewer, int documentOffset) {
WordPartDetector wordPart =
new WordPartDetector(viewer, documentOffset);
// iterate over all the different categories
for (int i = 0; i < allWords.length; i++) {
String[] list = (String[]) allWords[i];
// iterate over the current category
for (int y = 0; y < list.length; y++) {
if (list[y].startsWith(wordPart.getString().toUpperCase()))
proposalList.add(list[y]);
return turnProposalVectorIntoAdaptedArray(wordPart);
protected ICompletionProposal[]
turnProposalVectorIntoAdaptedArray(WordPartDetector word) {
ICompletionProposal[] result =
new ICompletionProposal[proposalList.size()];
int index = 0;
for (Iterator i = proposalList.iterator(); i.hasNext();) {
String keyWord = (String) i.next();
IContextInformation info =
new ContextInformation(keyWord, getContentInfoString(keyWord));
//Creates a new completion proposal.
result[index] =
new CompletionProposal(keyWord,
word.getOffset(),
word.getString().length(),
keyWord.length(),
null,
keyWord,
info,
index++;
proposalList.removeAllElements();
return result;
> -joe
> > nothing).
> > work:
> > return assistant;
Re: content assistant [message #177151 is a reply to message #176827] |
Thu, 08 January 2004 12:44 |
Regretfully, the code concerning content assistance remains the same
> this page:
> attention.
> -- Dan
> > -joe
> in
> Java
> > > nothing).
> to
> > > work:
> > > return assistant;
> me
Re: content assistant [message #177185 is a reply to message #176706] |
Thu, 08 January 2004 13:37 |
Originally posted by: hcs33.egon.gyaloglo.hu
I think you have to register the appropriate actions for your editor as
well. For example to use the content assistant feature for your editor you
need to do something like that:
public class YourEditor ...
protected void createActions()
super.createActions();
// Creates action for content assist (Ctrl+Space)
IAction action = new
TextOperationAction(TranslatorEditorMessages.getResourceBund le(),
"ContentAssistProposal.", this, ISourceViewer.CONTENTASSIST_PROPOSALS);
action.setActionDefinitionId(ITextEditorActionDefinitionIds. CONTENT_ASSIST_P
ROPOSALS);
setAction("ContentAssistProposal", action);
And in the resource bundle you use in TextOperationAction you can use
ContentAssistProposal.label=Content Assist@Ctrl+SPACE
ContentAssistProposal.tooltip=Content Assist
ContentAssistProposal.image=
ContentAssistProposal.description=Content Assist
After doing this Ctrl+Space should work.
For including content assist in the context menu (and the main Edit menu)
read Eclipse help-->Platform Plug-in Developer Guide-->Programmer's
Guide-->Editors-->Registering editor actions for details, it may help you.
HTH,
Csaba
> nothing).
> work:
> return assistant;
Re: content assistant [message #177660 is a reply to message #177185] |
Fri, 09 January 2004 12:30 |
This did the trick
Horváth, Csaba wrote:
> ROPOSALS);
> HTH,
> Csaba
> > nothing).
> > work:
> > return assistant;
Current Time: Sun Oct 06 12:19:09 GMT 2024
Powered by FUDForum. Page generated in 0.04156 seconds
