Re: Distributed Alternatives [message #3154 is a reply to message #1423] |
Sat, 18 April 2009 14:48 |
Originally posted by: alex_blewitt.yahoo.com
As you've already noted, this is specifically egit. However, a wider
discussion is available on bug 257706
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=257706). One of the things
I noted in my blog entry wrapping up EclipseCon was that one of the
inhibitors for the widespread adoption of SVN in Eclipse is due to the
fact the (xGPL) tools can't be distributed with Eclipse due to conflicting
with the EPL. So although the plugin might be under EPL, it has non-EPL
dependencies.
One of the strengths of EGit is that the library (JGit) is BSD which means
it can be redistributed from Eclipse.org. So whilst you're unlikely to see
an Eclipse release train with SVN or Hg support out-of-the-box, that might
not be the case for EGit.
In any case, the bug is the proper place to follow up on that aspect of
this discussion.
Alex
Re: Distributed Alternatives [message #499504 is a reply to message #3154] |
Mon, 23 November 2009 05:43 |
FYI: Now that svn moves to Apache I see a chance that svn migth become
part of the release train:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=294453
> things I noted in my blog entry wrapping up EclipseCon was that one of
> the inhibitors for the widespread adoption of SVN in Eclipse is due to
> the fact the (xGPL) tools can't be distributed with Eclipse due to
> conflicting with the EPL. So although the plugin might be under EPL, it
> has non-EPL dependencies.
> means it can be redistributed from Eclipse.org. So whilst you're
> unlikely to see an Eclipse release train with SVN or Hg support
> out-of-the-box, that might not be the case for EGit.
> this discussion.
> Alex
Re: Distributed Alternatives [message #575744 is a reply to message #3154] |
> this discussion.
> Alex
FUDForum. Page generated in 0.03291 seconds
