XML Data Source Example fails with BIRT 2.1 [message #176466] |
Tue, 11 July 2006 12:34 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: abushnaq.ricoh-europe.com
Does anyone know if this is a bug or I do something wrong.
With the XML Data Source example that can be found at:
http://www.eclipse.org/birt/phoenix/examples/reports/birt2.1 /xmlds/index.php
Previwing the report or running the report engine with BIRT 2.1 will fail.
Generated report is empty.
Error message:
The following items have errors: Data (id = 44): - There are errors
evaluating script "row["ReportName"]". Error.ScriptEvaluationError ( 1
time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are
errors evaluating script "row["ReportName"]". at
(If it helps I can add the actual dunp)
It worked with older versions of BIRT.
Re: XML Data Source Example fails with BIRT 2.1 [message #176545 is a reply to message #176466] |
Wed, 12 July 2006 03:21 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Can you post the example you are using.
I downloaded the example and it works fine in Eclipse designer and
row["ReportName"] is no where in the design.
Jason
"Abdalla Bushnaq" <abushnaq@ricoh-europe.com> wrote in message
news:8e42d5e1abf1dc38feb3c8e6b2ac34bd$1@www.eclipse.org...
> Error message:
> time(s) )
> errors evaluating script "row["ReportName"]". at ..
Re: XML Data Source Example fails with BIRT 2.1 [message #177565 is a reply to message #176545] |
Fri, 14 July 2006 07:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Jason
It is correct that row["ReportName"] is not used in the report and the
report engine fails with such a message. I also found this strang and
thought that it might be related with teh new layer introduced in BIRT 2.1
between the data sets and the tables.
Are you using BIRT 2.1 release version?
I was able to use a similar example with BIRT 2.01 without a problem.
I never tried a BIRT 2.1 beta or release candidate.
If you can run the example and I cannot, then I realy do not understand
what I do wrong.
BIRT should be compatible with Java 5?
There is not much I can realy do wrong because the example was working out
of the box with BIRT 2.01.
I realy would like to use BIRT 2.1 because of some interesting new
features. But currently all what I try with XML data source will fail in
the preview or reporting mode.
Re: XML Data Source Example fails with BIRT 2.1 [message #177661 is a reply to message #177565] |
Fri, 14 July 2006 13:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I am using Java 5 and BIRT 2.1.
Open the report, switch to the xml view copy and paste the results
to this thread. Also if you can post the whole error that would be good.
Jason
news:a60db7f17a70d60ca6cfc172375bde68$1@www.eclipse.org...
>> Jason
> what I do wrong.
Re: XML Data Source Example fails with BIRT 2.1 [message #177837 is a reply to message #177661] |
Sat, 15 July 2006 08:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: abushnaq.d.kamp.net
Thanks for helping,
OK, I redownloaded the demo from
http://download3.eclipse.org/birt/downloads/examples/reports /2.1/xmlds/XMLDS_After.rptdesign
I will post the report copied from my eclipse at the end of this message.
(this is getting realy long. is there a better way to attach sources?)
I also downloaded the image
http://download3.eclipse.org/birt/downloads/examples/reports /2.1/xmlds/Classic-Models-Minimal-M-Trans%20(smaller).png
Then I opened the report in Eclipse with BIRT 2.1 (This is the BIRT full
install).
I see an empty report. It does have a header and so, but no data.
Now to make sure I open the used data set and select "preview result". This
taks quit a while because it si a news feed, but the result will be shown.
I then try to select "View Report" in the menu. The report is generated but
the result is emty (looks same as in preview with header information but no
data) and has following error:
Data (id = 76):
- There are errors evaluating script "row["Channel Title"]".
Error.ScriptEvaluationError ( 1 time(s) )
errors evaluating script "row["Channel Title"]". at
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:572)
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:534)
org.eclipse.birt.report.engine.internal.executor.doc.Abstrac tReportReader$1.visitData(AbstractReportReader.java:320)
org.eclipse.birt.report.engine.content.impl.DataContent.acce pt(DataContent.java:111)
org.eclipse.birt.report.engine.content.ContentVisitorAdapter .visit(ContentVisitorAdapter.java:9)
org.eclipse.birt.report.engine.internal.executor.doc.ReportI temReader.initializeContent(ReportItemReader.java:237)
org.eclipse.birt.report.engine.internal.executor.doc.ReportI temReader.execute(ReportItemReader.java:57)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:35)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportExecutor.execute(LocalizedReportExecutor.java:90)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportExecutor.execute(LocalizedReportExecutor.java:98)
org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportExecutor.execute(LocalizedReportExecutor.java:77)
org.eclipse.birt.report.engine.internal.document.v3.ReportCo ntentLoaderV3.loadPage(ReportContentLoaderV3.java:50)
org.eclipse.birt.report.engine.internal.document.ReportConte ntLoader.loadPage(ReportContentLoader.java:56)
org.eclipse.birt.report.engine.api.impl.RenderTask.doRender( RenderTask.java:223)
org.eclipse.birt.report.engine.api.impl.RenderTask$PageRende r.render(RenderTask.java:593)
org.eclipse.birt.report.engine.api.impl.RenderTask.render(Re nderTask.java:524)
at org.eclipse.birt.report.service.ReportEngineService.renderRe port(Unknown
Source) at
Source) at
org.eclipse.birt.report.service.BirtViewerReportService.getP age(Unknown
Source) at
org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.doExecution(Unknown
Source) at
org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.__execute(Unknown
Source) at
org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(Unknown
Source) at
org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(Unknown
Source) at
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(Unknown
Source) at
org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPage(Unknown
Source) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at
java.lang.reflect.Method.invoke(Unknown Source) at
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(Unknown
Source) at
org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(Unknown
org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118) at
org.apache.axis.SimpleChain.invoke(SimpleChain.java:83) at
org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:453) at
org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 ) at
org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699) at
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(Unknown
Source) at javax.servlet.http.HttpServlet.service(HttpServlet.java:760) at
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853) at
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:247)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:193)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:256)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995) at
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199) at
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Unknown Source)Caused by:
java.lang.NullPointerException at
org.eclipse.birt.data.engine.impl.document.util.ExprResultSe t.getValue(ExprResultSet.java:131)
org.eclipse.birt.data.engine.impl.document.ResultIterator.ge tValue(ResultIterator.java:151)
org.eclipse.birt.report.engine.data.dte.DteResultSet.getValu e(DteResultSet.java:266)
org.eclipse.birt.report.engine.data.dte.NativeRowObject.get( NativeRowObject.java:90)
org.mozilla.javascript.ScriptableObject.getProperty(Scriptab leObject.java:1263)
org.mozilla.javascript.ScriptRuntime.getObjectElem(ScriptRun time.java:1301)
org.mozilla.javascript.ScriptRuntime.getObjectElem(ScriptRun time.java:1283)
at org.mozilla.javascript.gen.c28._c0(<inline>:1) at
org.mozilla.javascript.gen.c28.call(<inline>) at
org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:304) at
org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769) at
org.mozilla.javascript.gen.c28.exec(<inline>) at
org.eclipse.birt.core.script.ScriptContext.eval(ScriptContex t.java:224) at
org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:565)
.... 85 more
Data (id = 77):
- There are errors evaluating script "row["Channel Description"]".
errors evaluating script "row["Channel Description"]". at
Source) at
Source) at
Source) at
Source) at
Source) at
Source) at
Source) at
Source) at
Source) at
at org.mozilla.javascript.gen.c29._c0(<inline>:1) at
org.mozilla.javascript.gen.c29.call(<inline>) at
org.mozilla.javascript.gen.c29.exec(<inline>) at
.... 85 more
And new comes the actual report taken from the XML source tab from Eclipse
report designer:
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.2"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.1.0.N20060531-1258 Build <20060531-1258></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 Actuate Corporation.</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.xml"
name="Eclipse News Feed" id="48">
<text-property name="displayName">Eclipse News Feed</text-property>
<property
name="FILELIST">http://www.eclipse.org/home/eclipsenews.rss</property>
<property name="SCHEMAFILELIST"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.xml.dataSet"
name="Eclise News Headlines" id="49">
<text-property name="displayName">Eclise News Headlines</text-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">Channel Title</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">Channel URL</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">Channel Description</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">Channel Image URL</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">News Item Headline</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">Link To News Item</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">Short Description Of News Item</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">Publish Date of News Item</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Eclipse News Feed</property>
<property
name="queryText">table0#-TNAME-#table0#:#[/rss/channel/item]#:#{Channel
Title;String;../title},{Channel URL;String;../link},{Channel
Description;String;../description},{Channel Image
URL;String;../image/url},{News Item Headline;String;/title},{Link To News
Item;String;/link},{Short Description Of News
Item;String;/description},{Publish Date of News
Item;String;/pubDate}</property>
<property name="MAX_ROW">-1</property>
<property
name="XML_FILE">http://www.eclipse.org/home/eclipsenews.rss</property>
</oda-data-set>
</data-sets>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new
Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<grid id="4">
<property name="width">100%</property>
<column id="5"/>
<column id="6"/>
<row id="7">
<cell id="8">
<image id="10">
<expression name="uri">"Classic-Models-Minimal-M-Trans
(smaller).png"</expression>
</image>
</cell>
<cell id="9">
<text id="11">
<property name="fontFamily">"Arial"</property>
<property name="fontSize">x-large</property>
<property name="fontWeight">bold</property>
<property name="textAlign">right</property>
<text-property name="content"><![CDATA[News Feed Using XML Data
Source]]></text-property>
</text>
</cell>
</row>
</grid>
<table id="50">
<property name="dataSet">Eclise News Headlines</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression">dataSetRow["Channel Title"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Channel URL"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Channel Description"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Channel Image URL"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["News Item Headline"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Link To News Item"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Short Description Of News
Item"]</expression>
</structure>
<structure>
<expression name="expression">dataSetRow["Publish Date of News
Item"]</expression>
</structure>
</list-property>
<column id="63">
<property name="width">2.989in</property>
</column>
<column id="64">
<property name="width">3in</property>
</column>
<header>
<row id="51">
<cell id="52">
<property name="colSpan">2</property>
<property name="rowSpan">1</property>
<grid id="66">
<column id="67">
<property name="width">1.583in</property>
</column>
<column id="68">
<property name="width">4.333in</property>
</column>
<row id="69">
<cell id="70">
<image id="75">
<expression name="uri">row["Channel Image URL"]</expression>
</image>
</cell>
<cell id="71">
<data id="76">
<property name="resultSetColumn">Channel Title</property>
<structure name="action">
<property name="linkType">hyperlink</property>
<expression name="uri">row["Channel URL"]</expression>
<property name="targetWindow">_blank</property>
</structure>
</data>
</cell>
</row>
<row id="72">
<cell id="73">
<data id="77">
<property name="resultSetColumn">Channel Description</property>
</data>
</cell>
</row>
</grid>
</cell>
</row>
</header>
<detail>
<row id="54">
<cell id="55">
<grid id="78">
<column id="79"/>
<row id="80">
<cell id="81">
<data id="84">
<property name="resultSetColumn">News Item Headline</property>
<expression name="uri">row["Link To News Item"]</expression>
</structure>
</data>
</cell>
</row>
<row id="82">
<cell id="83">
<data id="85">
<property name="fontSize">8pt</property>
<property name="fontStyle">italic</property>
<property name="resultSetColumn">Publish Date of News Item</property>
</data>
</cell>
</row>
</grid>
</cell>
<cell id="56">
<text-data id="87">
<expression name="valueExpr">row["Short Description Of News
Item"]</expression>
</text-data>
</cell>
</row>
<row id="57">
<cell id="58">
<text id="65">
<text-property name="content"><![CDATA[<HR>]]></text-property>
</text>
</cell>
</row>
</detail>
<footer>
<row id="60">
<cell id="61"/>
<cell id="62"/>
</row>
</footer>
</table>
</body>
</report>
"Jason Weathersby" <jweathersby@actuate.com> schrieb im Newsbeitrag
news:e987i0$4a0$1@utils.eclipse.org...
> Jason
Re: XML Data Source Example fails with BIRT 2.1 [message #178037 is a reply to message #177837] |
Mon, 17 July 2006 15:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I cut your report and pasted into my 2.1 install and I am getting line feeds
in the xml design.
Did you download it by right clicking and saving as...? Don't open it and
cut and paste.
When you right click and save as make sure you change the file extension to
rptdesign.
Jason
"Abdalla Bushnaq" <abushnaq@d.kamp.net> wrote in message
news:e9ab4k$6mt$1@utils.eclipse.org...
> Thanks for helping,
> install).
> This taks quit a while because it si a news feed, but the result will be
> shown.
> but the result is emty (looks same as in preview with header information
> but no data) and has following error:
> Data (id = 76):
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:2769)
> at org.mozilla.javascript.gen.c28.call(<inline>) at
> ... 85 more
> Data (id = 77):
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> Source) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.mozilla.javascript.gen.c29.call(<inline>) at
> ... 85 more
> report designer:
> id="1">
> <data-sources>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <property
> <property
> </oda-data-set>
> </data-sets>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <grid id="4">
> <column id="5"/>
> <column id="6"/>
> <row id="7">
> <cell id="8">
> <image id="10">
> </image>
> </cell>
> <cell id="9">
> <text id="11">
> </text>
> </cell>
> </row>
> </grid>
> <table id="50">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> Item"]</expression>
> </structure>
> <structure>
> Item"]</expression>
> </structure>
> </list-property>
> <column id="63">
> </column>
> <column id="64">
> </column>
> <header>
> <row id="51">
> <cell id="52">
> <grid id="66">
> <column id="67">
> </column>
> <column id="68">
> </column>
> <row id="69">
> <cell id="70">
> <image id="75">
> </image>
> </cell>
> <cell id="71">
> <data id="76">
> </structure>
> </data>
> </cell>
> </row>
> <row id="72">
> <cell id="73">
> <data id="77">
> </data>
> </cell>
> </row>
> </grid>
> </cell>
> </row>
> </header>
> <detail>
> <row id="54">
> <cell id="55">
> <grid id="78">
> <column id="79"/>
> <row id="80">
> <cell id="81">
> <data id="84">
> </structure>
> </data>
> </cell>
> </row>
> <row id="82">
> <cell id="83">
> <data id="85">
> </data>
> </cell>
> </row>
> </grid>
> </cell>
> <cell id="56">
> <text-data id="87">
> Item"]</expression>
> </text-data>
> </cell>
> </row>
> <row id="57">
> <cell id="58">
> <text id="65">
> </text>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="60">
> <cell id="61"/>
> <cell id="62"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
>> Jason
Re: XML Data Source Example fails with BIRT 2.1 [message #180091 is a reply to message #178037] |
Wed, 26 July 2006 07:43 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Jason,
It looks to me as if your Eclipse version is reaction different then mine.
I downloaded my version as a birt-report-designer-all-in-one-2_1_0.zip.
This includes all needed plugins and Eclipse.
Did you use the same download?
I'm asking because it might be a problem with this install package that only
affects the XML data source.
news:e9g8s0$lrf$1@utils.eclipse.org...
>feeds in the xml design.
> cut and paste.
> to rptdesign.
> Jason
>> Thanks for helping,
>> install).
>> shown.
>> Data (id = 76):
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 85 more
>> Data (id = 77):
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> Source) at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 85 more
>> Eclipse report designer:
>> <?xml version="1.0" encoding="UTF-8"?>
>> id="1">
>> <data-sources>
>> <property
>> </oda-data-source>
>> </data-sources>
>> <data-sets>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> </list-property>
>> </structure>
>> <property
>> <property
>> </oda-data-set>
>> </data-sets>
>> <page-setup>
>> <page-footer>
>> <text id="3">
>> </text>
>> </page-footer>
>> </page-setup>
>> <body>
>> <grid id="4">
>> <column id="5"/>
>> <column id="6"/>
>> <row id="7">
>> <cell id="8">
>> <image id="10">
>> </image>
>> </cell>
>> <cell id="9">
>> <text id="11">
>> </text>
>> </cell>
>> </row>
>> </grid>
>> <table id="50">
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> URL"]</expression>
>> </structure>
>> <structure>
>> </structure>
>> <structure>
>> Item"]</expression>
>> </structure>
>> <structure>
>> Item"]</expression>
>> </structure>
>> <structure>
>> Item"]</expression>
>> </structure>
>> </list-property>
>> <column id="63">
>> </column>
>> <column id="64">
>> </column>
>> <header>
>> <row id="51">
>> <cell id="52">
>> <grid id="66">
>> <column id="67">
>> </column>
>> <column id="68">
>> </column>
>> <row id="69">
>> <cell id="70">
>> <image id="75">
>> </image>
>> </cell>
>> <cell id="71">
>> <data id="76">
>> </structure>
>> </data>
>> </cell>
>> </row>
>> <row id="72">
>> <cell id="73">
>> <data id="77">
>> </data>
>> </cell>
>> </row>
>> </grid>
>> </cell>
>> </row>
>> </header>
>> <detail>
>> <row id="54">
>> <cell id="55">
>> <grid id="78">
>> <column id="79"/>
>> <row id="80">
>> <cell id="81">
>> <data id="84">
>> </structure>
>> </data>
>> </cell>
>> </row>
>> <row id="82">
>> <cell id="83">
>> <data id="85">
>> </data>
>> </cell>
>> </row>
>> </grid>
>> </cell>
>> <cell id="56">
>> <text-data id="87">
>> Item"]</expression>
>> </text-data>
>> </cell>
>> </row>
>> <row id="57">
>> <cell id="58">
>> <text id="65">
>> </text>
>> </cell>
>> </row>
>> </detail>
>> <footer>
>> <row id="60">
>> <cell id="61"/>
>> <cell id="62"/>
>> </row>
>> </footer>
>> </table>
>> </body>
>> </report>
>>> good.
>>> Jason
Re: XML Data Source Example fails with BIRT 2.1 [message #180354 is a reply to message #180091] |
Thu, 27 July 2006 04:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I am using the same version.
Jason
news:ea76f2$uec$1@utils.eclipse.org...
> Hi Jason,
> only affects the XML data source.
>> and cut and paste.
>> to rptdesign.
>> Jason
>>> Thanks for helping,
>>> message. (this is getting realy long. is there a better way to attach
>>> sources?)
>>> install).
>>> shown.
>>> Data (id = 76):
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source) at
>>> Source) at
>>> Source) at
>>> Source) at
>>> Source) at
>>> Source) at
>>> Source) at
>>> Source) at
>>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at
>>> Source) at
>>> at
>>> at
>>> at
>>> at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 ) at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 85 more
>>> Data (id = 77):
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Source) at
>>> Source) at
>>> Source) at
>>> Source) at
>>> Source) at
>>> Source) at
>>> Source) at
>>> Source) at
>>> Source) at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 85 more
>>> id="1">
>>> <data-sources>
>>> <property
>>> </oda-data-source>
>>> </data-sources>
>>> <data-sets>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> </list-property>
>>> </structure>
>>> <property
>>> News Item;String;/link},{Short Description Of News
>>> <property
>>> </oda-data-set>
>>> </data-sets>
>>> <page-setup>
>>> <page-footer>
>>> <text id="3">
>>> </text>
>>> </page-footer>
>>> </page-setup>
>>> <body>
>>> <grid id="4">
>>> <column id="5"/>
>>> <column id="6"/>
>>> <row id="7">
>>> <cell id="8">
>>> <image id="10">
>>> </image>
>>> </cell>
>>> <cell id="9">
>>> <text id="11">
>>> </text>
>>> </cell>
>>> </row>
>>> </grid>
>>> <table id="50">
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> URL"]</expression>
>>> </structure>
>>> <structure>
>>> </structure>
>>> <structure>
>>> Item"]</expression>
>>> </structure>
>>> <structure>
>>> Item"]</expression>
>>> </structure>
>>> <structure>
>>> Item"]</expression>
>>> </structure>
>>> </list-property>
>>> <column id="63">
>>> </column>
>>> <column id="64">
>>> </column>
>>> <header>
>>> <row id="51">
>>> <cell id="52">
>>> <grid id="66">
>>> <column id="67">
>>> </column>
>>> <column id="68">
>>> </column>
>>> <row id="69">
>>> <cell id="70">
>>> <image id="75">
>>> </image>
>>> </cell>
>>> <cell id="71">
>>> <data id="76">
>>> </structure>
>>> </data>
>>> </cell>
>>> </row>
>>> <row id="72">
>>> <cell id="73">
>>> <data id="77">
>>> </data>
>>> </cell>
>>> </row>
>>> </grid>
>>> </cell>
>>> </row>
>>> </header>
>>> <detail>
>>> <row id="54">
>>> <cell id="55">
>>> <grid id="78">
>>> <column id="79"/>
>>> <row id="80">
>>> <cell id="81">
>>> <data id="84">
>>> </structure>
>>> </data>
>>> </cell>
>>> </row>
>>> <row id="82">
>>> <cell id="83">
>>> <data id="85">
>>> </data>
>>> </cell>
>>> </row>
>>> </grid>
>>> </cell>
>>> <cell id="56">
>>> <text-data id="87">
>>> Item"]</expression>
>>> </text-data>
>>> </cell>
>>> </row>
>>> <row id="57">
>>> <cell id="58">
>>> <text id="65">
>>> </text>
>>> </cell>
>>> </row>
>>> </detail>
>>> <footer>
>>> <row id="60">
>>> <cell id="61"/>
>>> <cell id="62"/>
>>> </row>
>>> </footer>
>>> </table>
>>> </body>
>>> </report>
>>>> good.
>>>> Jason
FUDForum. Page generated in 0.04292 seconds
