Home » Eclipse Projects » Eclipse Platform » Hot code replace error
Hot code replace error [message #176461] Tue, 06 January 2004 19:47 Go to next message
Originally posted by: eclipse.filter.verelst.net
I've given Eclipse another shot after not using it for over a year. I'm
very pleased with the speed and general useability of the latest 3M6
build. Almost everything I need work, except for the hot code replace.
I'm building a project with Ant into a webinf, which is then loaded by
Tomcat. Tomcat runs with jdpa enabled (eclipse connects like a charm!)
but when I modify code and save it, I get the following error message:
Reason:
Hot code replace failed - Scheme change not implemented
I have only one JDK installed on my machine, which is used by ANT and I
assume also used by Eclipse. Any thoughts on how to fix this?
Kind regards,
Johannes Verelst
Re: Hot code replace error [message #176493 is a reply to message #176461] Tue, 06 January 2004 20:51 Go to previous messageGo to next message
The hot code replace error you are seeing is a result of the VM not
supporting the HCR you are attempting (I believe you are attempting to add a
field?).
See
http://java.sun.com/j2se/1.4.2/docs/guide/jpda/jdi/com/sun/j di/VirtualMachine.html#redefineClasses(java.util.Map)
We are getting an UnsupportedOperationException if you are seeing that
particular error message.
In general you cannot change the "shape" of a class, neither add fields nor
methods with the generally available VMs, AFAIK.
So it is a limitation of the VM (unsupported operation) you are using and
not an Eclipse problem.
HTH
Darins
"Johannes Verelst" <eclipse@filter.verelst.net> wrote in message
news:btfkkc$1b7$1@eclipse.org...
> Reason:
> Kind regards,
> Johannes Verelst
Re: Hot code replace error [message #176661 is a reply to message #176493] Wed, 07 January 2004 06:48 Go to previous messageGo to next message
Thanks for your reply, but I should've given you more info on what I was
trying. I'm not adding fields or anything, just changing behaviour of a
method. The layout is like this:
function getFullVersion () {
return getMajor() + " " + getMinor();
I was changing this into a different string concatenation (specifically:
prefixing it with a fixed string).
Just to be complete, this is the output of 'java -version', in case it
might be related to this:
java version "1.4.1"
Java(TM) 2 Runtime Environment, Standard Edition (build
Blackdown-1.4.1-beta)
Java HotSpot(TM) Client VM (build Blackdown-1.4.1-beta, mixed mode)
Any thoughts?
Kind regards,
Johannes
> field?).
> See
> HTH
> Darins
>>Hi,
>>Reason:
>>Kind regards,
>>Johannes Verelst
Re: Hot code replace error [message #176677 is a reply to message #176661] Wed, 07 January 2004 07:05 Go to previous messageGo to next message
Have you tried with a non beta version of the VM?
Jerome
news:btgrcm$7ek$1@eclipse.org...
> Any thoughts?
> Kind regards,
> Johannes
add a
> > field?).
> > See
nor
and
> > HTH
> > Darins
> >>Hi,
> >>Reason:
> >>Kind regards,
> >>Johannes Verelst
Re: Hot code replace error [message #176684 is a reply to message #176677] Wed, 07 January 2004 08:17 Go to previous messageGo to next message
The JVM I first used was the standard JVM that comes in Debian/Unstable;
but after your suggestion I downloaded 'j2sdk1.4.2_03' from the Sun
homepage. I started tomcat using this JVM and also configured eclipse to
use this JVM for compiling and classpaths and such. Same problem occurs
Johannes
> Jerome
>>Hi,
>>Any thoughts?
>>Kind regards,
>>Johannes
> add a
>>>field?).
>>>See
> nor
> and
>>>HTH
>>>Darins
>>>>Hi,
>>>>Reason:
>>>>Kind regards,
>>>>Johannes Verelst
Re: Hot code replace error [message #176713 is a reply to message #176661] Wed, 07 January 2004 08:37 Go to previous messageGo to next message
Are you using JSP's? If so, the change that the Java VM sees depends on
the JSP to Java compiler in Tomcat (I don't know, might be a schema change).
Thomas
Re: Hot code replace error [message #176721 is a reply to message #176713] Wed, 07 January 2004 08:56 Go to previous messageGo to next message
> change).
Well, eventually I am using JSP's for frontend stuff, but I'm trying the
hot code replace on some core classes which are located in the .jar file
in the WEB-INF dir.
After some fiddling I've hit a point where I think the problem may lie:
the same class compiled by Ant (which I use to compile my project) and
eclipse (which compiles a file and tries to hot-replace it as soon as
you hit CTRL-S) differ. Using the unix command 'strings' on both files
give entirely different output. They are however using the same JDK for
compiling (I double-checked that in the properties), or is Eclipse
silenty still using it's own JDK for compiling?
First 5 'strings' output lines in eclipse-generated classfile:
org/mmbase/Version
java/lang/Object
class$0
Ljava/lang/Class;
Synthetic
First 5 'strings' output lines in ant-generated classfile:
class$org$mmbase$Version
Ljava/lang/Class;
Synthetic
<init>
Code
Now I can understand the JVM complaining about a scheme change; the
classfiles are completely different.
So, if this is the problem indeed, how to fix it? I've tried everywhere
in Eclipse but I can't seem to find any settings for this.
Johannes
Re: Hot code replace error - fixed [message #176763 is a reply to message #176721] Wed, 07 January 2004 10:10 Go to previous message
Apparently my idea of compile differences between Ant and Eclipse turned
out to be true. I figured out that changing the internal compiler for
eclipse isn't possible (good documentation!!), but I can ofcourse change
the compiler for ant ...
To all who have this problem in the future: do the following steps:
- add the 'jdtcore.jar' and 'jdtCompilerAdapter.jar' files to the Ant
classpath
- set the build-property 'build.compiler' to
'org.eclipse.jdt.core.JDTCompilerAdapter'
Let Ant recompile your entire project, and your set. Hot code replace
works like a charm now, meaning that developing and debugging my
software is going to be a LOT faster now.
Thanks all for helping me!
Johannes
>> on the JSP to Java compiler in Tomcat (I don't know, might be a schema
>> change).
> in the WEB-INF dir.
> org/mmbase/Version
> java/lang/Object
> class$0
> Ljava/lang/Class;
> Synthetic
> Ljava/lang/Class;
> Synthetic
> <init>
> Code
> Johannes
Previous Topic:Hot Code replace on linux ?
Next Topic:Any events like perspectiveDeactivated() ?
Current Time: Sat Nov 01 00:43:48 EDT 2025
Powered by FUDForum. Page generated in 0.05227 seconds
