Re: Java Editor frustrations [message #176460 is a reply to message #176318] |
Fri, 03 September 2004 09:56 |
Originally posted by: daniel.megert.gmx.net
David Hay wrote:
>Hi,
>Not sure if this is the right forum - a bit confused by all the different
>newsgroups!
>Anyway, just wondering if there any plans to provide the following in the
>Java Editor:
>- dragging highlighted areas
https://bugs.eclipse.org/bugs/show_bug.cgi?id=11624
>- highlight line with single click
Window > Preferences > Java > Editor, check "Show line numbers".
You can then click on the line number to select the line. Same works for
the text editor.
Dani
>If not, could someone point me in the right direction to customizing
>things myself?
>cheers,
>David
FUDForum. Page generated in 0.03979 seconds
