Home » Archived » BIRT » Report Engine - Supported Versions
Report Engine - Supported Versions [message #175879] Fri, 07 July 2006 09:26 Go to next message
orkus9 is currently offline orkus9Friend
i downloaded the newest Eclipse (3.2) and installed the newest Birt
(Version 2.1.0).
I want to use the Report Engine API (version 2.1.0).
I get the following error:
Error.DesignFileException.INVALID_XML - 1 errors found!
1.) ( line = 0, tag = null)
org.eclipse.birt.report.model.parser.DesignParserException (code =
Error.DesignParserException.UNSUPPORTED_VERSION, message : The report
file of version "3.2.2" is not supported.)
Why does the birt 2.1.0 not work with the report engine 2.1.0?
Which versions are supported by the report engine 2.1.0?
Is there a list of compatible versions?
Best regrads
orkus9
Re: Report Engine - Supported Versions [message #175947 is a reply to message #175879] Fri, 07 July 2006 13:11 Go to previous message
it was a big mistake of me. I deployed the wrong birt-report-engine
version. now it works fine.
Best regrads
orkus9
Orkus schrieb:
> (Version 2.1.0).
> Best regrads
> orkus9
Previous Topic:Hiding AJAX components
Next Topic:IIS Birt Web Viewer
Current Time: Thu Dec 26 16:10:13 GMT 2024
Powered by FUDForum. Page generated in 0.02986 seconds
